Tip & How-To about Miscellaneous
Monel 400 Pipe Fittings
Monel as an alloy, contains 65 to 70 percent of nickel, 20-29 percent of copper, and small amounts of iron, manganese, silicon and carbon. Although it is much stronger than steel, it can have a problem of surface discolouration, which occurs when exposed to atmospheric conditions. Monel is generally resistant to to corrosion agents, mainly rapidly flowing sea water. They are fabricated readily by hot-and-cold working, machining and welding. In terms of properties, Monel is a single based alloy. As compared to steel, Monel is very difficult to fabricate or develop because it work-hardens while processing very quickly. Naturally, it is quite resistant to corrosion and acids, and some types of alloys can withstand fire and heat in pure oxygen to a certain limit.
Monel 400 Pipe Fittings at Instinox is backed by all world class certifications including ISO 9001:2008, ISO 14001:2004, OHSAS 18001:2007 & CE-PED 97/23/EC. We are also members of various renowned agencies and Chambers of Commerce including MASSMA, EEPC, FICCI, FIEO, Indian Merchants Chamber etc. Our Monel 400 Pipe Fittings at Instinox carry our brand identity with a special brand marked on the fittings. Our brand i-Fit is branded on all pipe fittings exported from our company. Monel Pipe Fittings Manufacturers Suppliers Instinox
Miscellaneous Logo
What is the difference between mild steel and stainless steel? Which is more stronger?
Stainless steel is stronger. It has a mix of other metals like chromium and vanadium which makes it stainless and generally more rustproof.
Mild steel is cheaper and is also known as high carbon steel. This is a softer steel and rusts very easily.
Jan 04, 2016 | Maytag MFI2568AES Stainless Steel Bottom...
is menudo bad for you?
this soup isn't very high in nutrients, although it does contain 4 to 5 percent of the daily value for iron, vitamin A, potassium and phosphorus in each serving. You need iron for forming red blood cells, vitamin A for healthy vision, potassium for counteracting the blood-pressure raising effect of sodium and phosphorus for forming strong bones. The only vitamin or mineral typically found in large amounts in menudo is sodium, which you want to limit in your diet. Each 1-cup serving of menudo contains 971 milligrams, or 40 percent of the DV for sodium.
Sep 01, 2014 | Miscellaneous
Have a 350 block, 3970010. With 0.10 S stamped on it. What is the S for
The "010" embossing on your small block chevy indicates that the block is 10 percent nickel/iron alloy. These "010" blocks can be of either "2 bolt or 4 bolt" crankshaft main cap variety. The 020 blocks are rare, but preferable to 010 blocks as they are 20 percent nickel to iron and are stronger. The higher nickel content makes for a slight add in weight, but a much stronger block. The "S" I'm not sure of yet.
Aug 06, 2014 | Cars & Trucks
What minerals are found in apples?
Apple Calcium Copper Iron Magnesium Manganese Phosphorus Potassium Selenium Sodium Zinc
Jan 17, 2013 | Cooking
58 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
