Tip & How-To about Miscellaneous
A fast fix to solder a water pipe that won't stop driping long enough to solder it
If you need to solder a copper water pipe but the water will not stop driping out' just take a small piece of bread and stick it in the pipe make sure you don,t pack.it in to tight , the bread act's like a sponge to stop the water long enough to solder it than turn the water on and the bread will flush away.
Miscellaneous Logo
I am making a plumbing repair to copper pipe. There is a small trickle of water that I cannot stop flowing. What is a good way to block the water to make a good joint?
Jamb a piece of white bread(wadded into a tight ball)into the pipe. Work fast. Bread will stop flow for a bit, but will breakdown quickly under pressure and dissolve with no blockage.
May 04, 2017 | Plumbing
I have a pin hole in my copper pipe
first of all shut off the water to the area and see if the flow has ceased, if you still have a trickle of water you will not be able to solder the pipe. Any water flow will make the repair impossible. If you can get the water to slow to a trickle you will need to cut the pipe in half and solder a sleeve in its place at the cut. once the pipe is cut you can take a peice of bread, yes bread, and pack the incoming water side and this will stop the flow long enough for repairs to be made. The bread will break down to minute particles after the soldering is done and shouldn't hurt the system at all. If it is impossible to cut the piping at the area there is a pipe patch that you can purchase at most local hardware stores the wont require the water to be shut off however, this is a temporary repair and may start leaking again in the future. Good Luck on your repairs Hope I have helped you some
Dave
Jan 08, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
92 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
