Tip & How-To about Audio Players & Recorders
Repair lavalier microphone
Lavalier microphone usually breaks by the cable, near the clip, 'cause talents mess with it during shots. here you will understand how to fix it.
Don't know what is the brand of this mic, but if have one that is similar, quite shure it will be fixed in the same way.
Detach mic from body pack or by phantom power injector.
Cry for the mess your collegues make with mic cables ...
Detect the problem ... in this case is clear u have to cut a piece of cable and resolder the capsule
with two pliers, gently twist the two pieces of the capsule to unscew it.
Now you have access to the mic PCB, solder points etc.
When you will cut the damaged part of the cable remember to re-set screen and vibration pad in the same order like it's now (use that hoto as reference).
Take note of where shield and signal are soldered (mic do not work if reverse biased or works very bad ... and could be damaged)
Desolder the cable and cut the damaged part.
Strip the cable tip (and recycle the plastic cover to insulate ground shield.
Pre-solder signal and shield tips.
Set on the cable bumper and screen NOW (if you removed them) :D
Carefull position cable in correct position (remember the polarity you noted before).
pre-soldered tips touching the right pcb position.
Gently position soldering iron on the tips. Soldering on both sides (cable tip and pcb) will fuse and make the electric contacts.
It's time to re-assemble the whole thing.
Make a knot on the cable or use a cable tie to add mechanical strenght to the cable :D
Now your mic is (quite) new. Connect body pack or the phontom power injector and check it on your equipment.
Happy fixing :D
akg c4000b hum
usually humming is caused by defective cables. Check if the cable is wired correctly. Open both XLR plugs and check:
Pin 1 shield
Pin 2 hot (usually red wire)
Pin 3 cold (black, blue or whatever)
Pinnumbers are written near pins usually.
If that doesn't help shake the cable for contact issues.
The microphone could have a broken shield connections as well. Maybe there's a small screw near the XLR output connector. Unscrew (sometimes this screw needs to be turned CLOCKWISE) and check connections.
Apr 15, 2014 | Audio Players & Recorders
pro 70 lavalier mic- is there away to hook the pro 70 lavlier directly to your computer or mic WITHOUT a mixer or amplifier?
On microphone input of your soundcard if it is not there then sorry you need a tiny amp as the other inputs are all at line level
Jan 22, 2014 | AUDIO-TECHNICA U.S. INC. PRO 70 Cardioid...
Shure SM93 lavalier microphone will not work
Make certain phantom power is turned on. The SM93 reqjuires phantom power from the mixer.
Sep 24, 2013 | Shure SM93 Micro-Lavalier Consumer...
Fender Passport 250:
The manual is here if you don't have one:http://www.fender.com/support/manuals/pdfs/manuals_elec/fenderaudio/PassportP250.pdf Have a look at page 9 and read the VIP Channel 1 only section. It will explain the solution to your problem and the settings to overcome it. Please let me know if this helps.
Nov 29, 2009 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
Cable break!
1. clear cut off the damaged section,
2..solder or ideally wire-wound the connections,
3. insulate the wires with plastic tape, or plastic sheet,
4. shield the wires with aluminum foils,
5. wrap up the outer.
6. done.
good luck
pc-cook
Nov 19, 2007 | Fishman Full Circle Upright Bass Pickup...
927 people viewed this tip
 Grubhead
Grubhead
