Tip & How-To about Whirlpool Duet GHW9150P Front Load Washer
ERROR CODES DISPLAYING ON VARIOUS WASHING MACHINES ARE BASIC
Sometimes you will see an error code displayed on a front loader. Alot of times these error codes displayed can be generically for other reasons leading up to that specific code.
Get on fixya and explain what has happened in the recent usage of seeing this error code, it helps us answer your question, in other words be specific on the brand and a little details of if it happened all of a sudden, or if you have noticed things, then you are on your way to getting a better curtailed answer to the problem and could be alot quicker at the resolution.
Whirlpool Duet GHW9150P Front Load Washer Logo
i have a Whirlpool front loader it gives me a
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 29, 2010 | Whirlpool LHW0050PQ Front Load Washer
F21 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
This helped my husband fix our washer. We had 5 baby socks clogging up the washer from draining. I guess we will need to use a laundry bag to wash little baby things.
Apr 05, 2010 | Kenmore Elite 45986 Front Load Washer
F21 Error Code
you saved my life thank you so much it was a 15 min fix and yes washer do eat socks.
Dec 09, 2009 | Washing Machines
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
This fixed my problem exactly! baby clothes had wound up in the trap... ugh
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
1,542 people viewed this tip
Dan Webster
Dan Webster
Sal DeAngelo
