Tip & How-To about Moultrie Panoramic 150 Trail Camera
Moultrie Panoramic 150 Trail Camera freezes or stuck in unlock mode
This unit is quirky, but has a robust user menu. The biggest problem is the security code entry mode sometimes gets stuck, and you can't get into the programming mode. Other modes get stuck for various reasons.
Here's a little inside for problems entering into the programming mode for the P-150
If you enter your security code, and the screen freezes and won't unlock, get this.
It took me a long time to figure this out, and nothing in the manual or online will help you get unstuck from the security code mode.
A little something on the side first, so take note when considering purchasing this beast:
Customer service at Moultrie is almost non-existent, and they refuse to attempt any repairs on cameras past it's warranty period. Nice, huh? End user, end of the line if you have a dead stick past the one year warranty, and no repair facility. Nothing like getting stuck with a $250-350 unit and no repair capabilities from the manufacturer. People working the phones have attitude, so nothing like adding insult to injury. If you forget you security code, try calling customer service for an unlock code bypass
zzzzzzzzzz....................
Try the following fix. May cure problems with menu items getting stuck too, just not sure. Problems with getting out of the security code mode, freezing up:
Your memory card is unformatted.
Your memory card is bad.
Your memory card has bad sectors or unreadable.
Take card out of camera. Load it into your laptop, and click icon. Windows will look for drive errors, and ask permission to repair.
If the card is bad, it will tell you. If not, click yes and wait for completion.
I would format the card in your laptop, not the camera format option. Just a thought.
Hope this helps folks out there, it took me several attempts over a year to get back into the programming menu, having to settle for that ridiculous Panoramic Hybrid default mode because I couldn't enter into the unlocked programming mode. Sure hope this helps hunters out there
Moultrie Panoramic 150 Trail Camera Logo
brother DC8060 how to reset fuser life
ENTRY INTO THE MAINTENANCE MODE
Press the [Menu] and [Start] keys. Next press the [/\] key four times to make the machine enter the maintenance mode.
FAX models equipped with numerical keypads can enter the maintenance mode by pressing the [Menu], [*], [2], [8], [6] and [4] keys in this sequence.
The machine beeps for approx. one second and displays MAINTENANCE " on the LCD,
indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys.
To select one of the maintenance-mode functions press the [/\ ] key or [\/ ] key to display any function code on the LCD. Then press the [OK] key 88 Counter Reset After Replacing the Fuser Unit, Laser Unit and
Paper Feed Kit
Jul 21, 2014 | Brother MFC Office Equipment & Supplies
i forgot my nokia c1-01 security code
The default code supplied with the device is 12345. However, it is recommended to change the default code to your own. The instruction on how to change the security code is provided in the user guide or Nokia Web site.
Keep the new code in a safe place separate from your device.
If you get error notifications after 3 consecutive times security code entries, reboot the device and wait for 15 minutes, then try again. If the problem persists, contact your local Nokia Care Point.
Oct 12, 2013 | Nokia C101 Cell Phone
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
I need a remote for my RCA DVD player, model DRC282. I haven't had much luck with a couple of universal remotes. Any help would be appreciated.
Just try a code search process. Sometimes it might help you:
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
May 12, 2012 | Televison & Video
I have a citizen television & the code is not in the list to program the remote, i can't get the remote to do anything. Is there a code for a citizen tv?
Hello
Try a code search method. Sometimes it may halp you.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK.
Jul 23, 2011 | Sony RMEZ4 Remote Control
924 people viewed this tip
Top Moultrie Video Cameras Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
