Tip & How-To about Miscellaneous
How to speedup the Android mobiles
1. Clean the junk files regularly
2. Delete the temp files of uninstalled apps
3. Don't recharge your phone over 3 hours a day.
4. Keep your mobile @ room temperature
5. Don't overload the memory space.
6. At least free up your memory space about 1.5 GB for 8 GB Storage devices.
Miscellaneous Logo
How do I delete phone messages
What kind of phone is it? If you're on an iPhone, then you can delete the conversations in your iPhone Messages app to delete the messages. You only need to swipe the conversation from right to left to delete the messages.
delete-phone-messages-oxaxc0rwhkhzilrwacqreyis-3-0.jpg How to Delete History on iPhone
Sep 22, 2016 | Cell Phones
how to fix 0xc000007b problem
This Microsoft Office error code occurs when you are updating installing and copying etc. This error occurs due to router and modem configuration and ISP restriction.
This error can be solved in 4 ways
1. By cleaning temp folder
2. By cleaning the %temp% folder
3. By cleaning the system file
4. By cleaning the Internet Explorer junk
Guide to solve your issue
Open the Run by pressing the window + R keys
Then open the temporary file system location by searching the temp in command prompt
If you have files means then select all the files and clear them by pressing Shift + Delete
This is also similar to clear the temp folder. By this method, we clear the user junk files.
Instead of temp search as %temp% in command prompt and follow the above steps.
Open the Run command prompt
Enter the cleanmgr command
Then select the drive which one want to clean
Then scan for junk data after that choose the entire item from the list except the recycle bin to clean.
Open the run window and enter the inetcpl.cpl command
Then go to advanced tab and select the reset button to clean the junk data
Then you will get pop up to delete the personal settings click ok to delete.
By following the above steps you can resolve your windows error code issues. For further more guidance regarding windows, you may visit the Microsoft Support Number.
Aug 30, 2015 | Computers & Internet
family feud won't open on iphone
Mine has the same issue. and don't worry, Its NOT your internet. its the app. Everything else on my phone works, other games, I can get on the internet no problem. just this app.
Apr 25, 2012 | Ludia Family Feud™
I am getting this error when trying to install anything on my win 7 ultimate. is there anything i can do to fix this? Says exactly this: "1152: Error Extracting c:\Users\Robert\Appdata\local\temp\[f2fbb19 to the temporary location" Anything please. cant install anything
1- Uninstall all the programes in control panel which you think you don't require
2- delete all leftover folders in program files outspark etc.
3- click start > run > type %temp% and delete ALL the files in that folder
( There will be like 3-4 u can't delete, dont worry about it ) also make sure you uninstall and delete the launchers.
4- Re download the PROGRAME ( INSTEAD of Saving it to DESKTOP, Save it somewhere else Like My Documents, Run it, And there you go problem solved.
At least that is how it worked for me, every time i was having that error i was saving it to desktop, after i did all the steps before and changed the location to my documents, it installed without any problems.
Aug 11, 2011 | Computers & Internet
124 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
