Tip & How-To about Miscellaneous
WINDOWS 10 - MONITOR TURNS "BLANK" (SLEEPS) AFTER 1 MINUTE AT LOCK SCREEN
Even if you have set the following settings to:
"Never turn off the Display" & "Never put the Computer to Sleep", you can still have Windows 10 turn off the display after 1 minute at "Lock Screen".
If you don't want the Monitor to turn off, do the following:
1) Click with the Mouse on the "Search Windows Icon" in the lower left corner of the monitor, and in the "Search Windows" space type: "Screen Saver". When the Menu appears, Click with the Mouse on "Turn Screen Saver on or off". Then, on the Screen Saver Tab under "Screen Saver", set it to "None" instead of "Blank".
Note: If the setting is set to "Blank", Windows 10 will assume that you want to 'Blank' (i.e. Windows discriminate between "Turn Off" & "Blanking the Monitor") the Monitor after a specified time period - even though you have set the other settings mentioned in the beginning of this writing to "Never turn off the Display" & "Never put the Computer to Sleep".
That's it, I hope it will help someone else as I found that many have this issue with Windows 10 & Windows 8, 8.1.
Miscellaneous Logo
what does "on battery" &
It's an auto lock setting wherein you can set the time when the display goes on sleep. If for example, it runs on battery and you want the display to go off after 5 minutes so you can save battery, you can set it to that. If it's plugged in charger and you don't want the display to go off, you can set it to never so it doesn't lock the phone and acts as a real alarm clock.
Mar 06, 2011 | Cell Phones
jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
MY asus pc continues to not wake up. I have to
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 15, 2010 | ASUS Eee PC 900 Notebook
screen goes blank after a few minutes
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 14, 2010 | Dell Inspiron 1318 Notebook
Think pad t42 monitor keeps turning off. I tried changing power settings to never ... did not help still doing the same thing anything else I can do? thanks
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 02, 2010 | IBM ThinkPad T42 Notebook
133 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
