Tip & How-To about Electrolux EI30EW45JS | 30" Double Wall Oven IQ-Touch Controls - Stainless Steel
Oven stopped working after self clean
Electrolux Double Oven EI30EW45JS1
After a self clean cycle the top oven stopped heating up. The keypad was operational, but there were no error codes. I determined this was due to the thermal switch being tripped. Unfortunately the oven has to be removed from the wall to get to the back where the switch is located.
Here is what I did:
1) Remove any trim around the oven in prep for sliding it out (see installation instructions).
2) Slide it out with a friend, on to a hydraulic table cart (1 used a 500 lb capacity one)
3) unplug the oven and remove the back panel.
4) Either reset the thermal switch by pressing the red button, or replace it. I found mine located on the upper left (facing it from the front)
5) replace the back panel
6) plug the oven back in
7) slide it back in place
8) replace the trim
The hardest part is getting the oven out, so I just replaced the switch and everything worked fine.
Electrolux EI30EW45JS | 30" Double Wall Oven IQ-Touch Controls - Stainless Steel Logo
Power Surge Electrolux double oven EI30EW45JS, now producing F11 code, installed new board, how to reset to see if problem is fixed?
Good Morning Jennifer Lynch, thanks for your post!
I see you have replaced the control board on your Electrolux wall oven and it is displaying an "F11" error code. "F11" stands for a shorted keypad, since you have replaced the board I would recommend resetting your wall oven. You can reset your wall oven by flipping the household circuit breaker off for ten minutes. If you need further assistance please feel free to reconnect. I hope this is helpful. -Matt
Oct 13, 2014 | Electrolux EI30EW45JS | 30" Double Wall...
Indoor unit fan blows, then stops etc. every 1-2 minutes
At least it is cooling properly. U might just want to call Mitsubishi and ask them if it is operating normally based on your observations.
Apr 30, 2017 | Mitsubishi 18000 Btu Mr.slim Ductless Mini...
Oven won't heat
I believe you popped your breaker at the box. If it does not reset then you have to replace the breaker itself.
Oct 07, 2012 | Whirlpool RBD307PVS 30 Double Electric...
PROBLEM WITH BREEZE AT
It sounds like the fan motor may need to be oiled, front and rear. That has been my experience with stopping and starting at that length of interval.
Jul 26, 2008 | Ecoquest Breeze AT Living Air Purifier
243 people viewed this tip
Top Electrolux Air Purifiers Experts
Richard Lane
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
