Tip & How-To about Hayward SAND FILTER, PRO SERIES
Pool filter lets sand through
At least in Europe since some 5 years ago, standard sand sold for your pool filter is much finer (smaller gauge), and older filters (mine being some 15 years old and working perfectly up until then) let this finer sand through. Solution: only one I ever found after much trying and problem-solving was to change the filter entirely. Costly, but no problem since.
Hayward SAND FILTER, PRO SERIES Logo
what is best "sand" to use in filter?
It is called diatomaceous earth for pool filters.
Dec 22, 2014 | Pool & Spa
I have 7 year old Hayward ProSeries, S-244S, H/R Sand filter. I've notice that when I vacuum the pool, dirty water returns to the pool. I've backwashed and the spider gasket is fine. No sa
sand filters only have limited filtration. If the dirt is very fine such as dead algae, it will go right through the filter. Use a clarifier to help give the filter finer filtration. Do not vacuum until you can see what you are doing, then vacuum on 'waste'
Sep 19, 2012 | Hayward SAND FILTER, PRO SERIES
pool filter not doing its job
try using a clarifier that you add into the skimmer such as Clearex 500.
The flocculent only makes particles drop to the pool floor, a liquid clarifier actually coates the sand and will filter smaller particles. Also, check the o-rings on the backwash valve. If the o-ring(s) are damaged it may be letting some water bypass the filter.
Sep 06, 2009 | Astral Products Difusser 1/2 Hp - 1 1/2 Hp
can i hook up a intex pump to a sand filter
YES BUT PRICE OF SAND FILTER WILL PROBALLY COST MORE THAN THE POOL ITSELF
Jul 13, 2009 | Intex 2500 Gallon Sand N Sun Pool...
Intex Easy Set 530 Gallon Swimming Pool Filter Pump does this keep your pool clean when running all the time?
No, the filters/pumps are much to weak. Not only is that filter too small for the pool but it is a cartridge filter which is the cheapest form of filtration. I hate to break it to you but a good pump/motor/filter is going to cost you around $600-$800.
Jul 05, 2009 | Intex Easy Set 530 Gallon Swimming Pool...
298 people viewed this tip
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
