Tip & How-To about Ankaka.com Car OBD-II Diagnostics Tool with 4 Inches Screen
Why to choose the Opcom diagnostic tool?
Opcom 2009 V Can OBD2 for Opel
Opcom 2009V Function:
1.The program lets you to read out and clear fault codes, shows you live data, lets you to perform output test.
2.The program supports many control units, like Engine, Automatic Transmission, ABS, Airbag, Engine Cooling module, Instrument Cluster, Electronic Climate Control, Body Control Unit, just to name a few examples.
3.Since Opel uses many pin in the OBD connector, the diagnostic interface works as a multiplexer, and selects the appropriate pin for communication.
PIN3, PIN7, PIN8, PIN12 = Serial Link (ISO9141, KW81, KW82, KWP2000)
4.Fault codes will be shown with all available information:
http://eforshop.en.alibaba.com/product/60451426107-803036758/Opcom_2009_V_Can_OBD2_for_Opel.html?spm=a2700.7724838.0.0.XRxhY0
Ankaka.com Car OBD-II Diagnostics Tool with 4 Inches Screen Logo
how important the crash sensor is?
In states where you get emission checks, it is important. If you don't have one you will also have the Check Engine light on.
Opcom OP-Com 2010 V Can OBD2 Opel
Dec 11, 2012 | 1999 Toyota Camry
Can I clear ABS code with OBD II USB Software for a 1998 Durango?
Hello! Yes there is a scanner that will reset an ABS code, providing there is no longer a fault...Go to the link below for an example...Guru...saailer
http://www.devildogtools.com/otc94obdiisc.html?AdID=1279--OTC9450
May 04, 2012 | Cars & Trucks
217 people viewed this tip
Top Ankaka.com Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Ankaka.com Office Equipment and Supply Expert? Answer questions, earn points and help others
