Tip & How-To about Miscellaneous
Brass fittings
Brass is a yellowish shiny type of alloy, which mainly consists of copper and zinc, usually 67% copper and 33% zinc. Brass and Bronze are two completely different alloys since bronze mainly consists of copper and tin. Brass might also contain other elemental metals such as arsenic, phosphorous, aluminium, manganese and silicon. Lead has a low melting point, so in some cases, they are added in concentrations to increase the machinability of the brass.
Brass fittings at Instinox is backed by all world class certifications including ISO 9001:2008, ISO 14001:2004, OHSAS 18001:2007 & CE-PED 97/23/EC. We are also members of various renowned agencies and Chambers of Commerce including MASSMA, EEPC, FICCI, FIEO, Indian Merchants Chamber etc. Our Brass fittings at Instinox carries our brand identity with a special brand marked on the fittings. Our brand i-Fit is branded on all pipe fittings exported from our company.
Pipe Fittings Manufacturers Suppliers Instinox
Miscellaneous Logo
Is nickel the same as silver?
no
two totally different metals
May 13, 2018 | The Computers & Internet
What materials are fasteners made out of?
Fasteners are usually made from carbon steel. In fact, over 90% of them are made from this material. This is because carbon steel has many properties that make it ideal for industrial use, such as its workability, strength properties, and affordability. There are different types of 3 different types of carbon steel which have different properties.
These are:
1. Mild steels - Under 0.25% carbon content, inexpensive, great toughness and ductility.
2. Medium carbon - 0.25% - 0.60% carbon content, very ductile, good load carrying ability
3. Alloy steel - Either 1.65%+ manganese content, 0.60%+ silicon, copper content, 4%-chromium content, or contains a specified minimum content of aluminium, titanium, vanadium, nickel or any other element.
Other materials can be used in fasteners too. For example, I took a look at some supplier websites and found that some nuts, like the ones available at http://www.keyfasteners.co.uk/rail-nuts.htm, are available in many different materials, including steel, stainless steel, brass, bronze, light alloy and titanium.
May 08, 2018 | Cars & Trucks
what are some examples of metallic bonds
Metallic Bonding Examples
Like NaCl is an example for ionic bonding, various metals like iron (Fe), lithium (Li), potassium (K), gold (Au), silver (Ag) are all examples of metallic bonding. Even the alloys of metals are the perfect example of such bonds. Brass, an alloy of copper and zinc, Terfenol-D (a magnetostrictive alloy) and various chemical elements are some other examples of compounds that consist of metallic bonds. Most of the metals have only one or two valence electrons and their ionization energies are very low, that is, the valence electrons are not very tightly bound to the atom and they are easily mobile from one to the other atom. This ease with which mobile electrons move in a crystal lattice determines the bond, that means, ionic, covalent or metallic. The properties exhibited by metals are due as mentioned in the above paragraphs. For instance, consider gallium, molten gallium is a very non volatile liquid in its molten form and it is due to the strong metallic bonding in gallium.
Metallic bonding forms one of the various forms of chemical bonds studied in chemistry. This was some brief information on this form of bonding that is the main reason for various physical properties of metals.
Read more at Buzzle: http://www.buzzle.com/articles/metallic-bonding.html
Nov 14, 2012 | Computers & Internet
What are the main metals consist in a knife's blade?
There are many metals used to assemble a knife, but the main blades are forged from bronze, copper, iron, steel, ceramics, and titanium. If you're buying a new knife I recommend to use titanium made knife, it's very high quality an titanium is the best stainless steel.
Jul 25, 2012 | Camping, Backpacking & Hiking
mycopperline that i got on my carb needs welding from copper to aluimene what do i use
There is not usually copper lines on carbs, it is usually brass\bronze.
Epoxy araldite glue may be best, just dont get any inside the tube
Apr 18, 2011 | Suzuki GSX 600 F (Katana Motorcycles
73 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
