Tip & How-To about Miscellaneous
A thing to remember when buying parts.
Placed your self in driver's seat or behind handle. Left is left side Right is right side
Miscellaneous Logo
I have a zero turn cub cadet. Left arm will engage and work properly. When I engage right arm nothing happens. Main belt looks fine. what could be the problem? Thanks for any help!
few things to look at ,
1st with mover off , look to see that handle for right side is still connected to directional control valve (pins fall out) it's back under the seat just behind your foot position, a cover or two maybe removed to see it
2nd cubs use a (dual) solenoid ckt to verify that operator is in seat (safety), since left side is working , the problems not your seat switch but might be the wire going to right sides control valve
May 07, 2015 | Garden
getting temperature right on monarch mixer shower
As long as your not using it, take off the handle with a phillips and you'll find your temperature mechanism behind it. Make sure the arrows are aligned. Typically hot is on the left and cold on right, unless the shower shares pipes with another water device on the opposite side of the wall. Plumbers save time, money, and copper by using the same pipes for closely placed water devices on opposite sides of the wall.
Nov 17, 2011 | Home
Where is the computer box in the Lexus LS400 located?
There are 11 electronic control units(ECU) located in the dash area. They are as follows.
Engine + trans. ecu. behind right side of the dash.
Abs + traction ecu. beside the engine ecu.
electric mirror ecu. behind upper right side of dash.
SRS ecu. behind dash at console.
Shift lock ecu. in center console near shifter.
Power seat ecu. under drivers seat.
progressive power steering ecu. behind left dash left of column.
Steering column tilt + telescopic ecu. behind left dash above column.
Anti-theft ecu. behind far left of dash.
Cruise control ecu. just below the anti-theft ecu.
My guess is you are looking for the engine ECU but you may be
looking for 1 of these in the future. Hope this helps.
Sep 30, 2010 | 1991 Lexus LS 400
suround sound speeker system for sony
It's very simple. The center speaker should be directly in front of you, usually where the TV is located and the front left and right should be at the side of the TV (left and right), the two rear speakers should be anywhere behind you and the subwoofer can be placed anywhere in the room. The front speakers and center should be within 6' to 10 feet from the seating position and the rears can be anywhere behind the seated position.
Hope that helps.
Jul 19, 2008 | Wave Audio CS801 Speaker
75 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
