Tip & How-To about Watches
WR30M Sports Watch: How to ... instructions
I found this link on another site. It explains the four buttons, and I was able to use it to solve all my WR30M problems.
http://www.dakotawatch.com/PDF_FILES/Digital.pdf
Watches Logo
My Watch is showing military time but i want it to show in the 12 hr clock
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
http://www.fixya.com/support/t6812987-change_timex_wr30m_from_24_hour_12
How do change my timex wr30m from 24 hour to 12 hour display
Mar 21, 2018 | The Watches
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
turning off alarm on Model: WR30M?
Google (fossil)(WR30M)(manual) without parens for instructions.
Apr 05, 2014 | Fossil Watches
Setting Time and Date on a Timex WR30M
1) Press and hold mode for about 2 seconds and then release. You will now be in the alarm edit mode.
2) Press mode once more and now you are in time edit mode.
3) Use the stop button to select what to edit, i.e. hour minute, etc.
4) Use the reset button to make the changes once you have selected the hour/minute, etc. that you want to change.
5) Press
Mar 07, 2008 | Watches
447 people viewed this tip
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
