Tip & How-To about Microsoft Computers & Internet
DIY keyboard shortcuts
Windows has a ton of keyboard shortcuts baked right in, but you can roll your own to open the software of your choice lickety-split-no mouse-clicking or launcher-hunting required.
Right-click the program's launch icon and select Properties. Open the Shortcut tab, then click in the "Shortcut key" field and press the key you want to use to launch the program. Windows will assign Ctrl + Alt + as a keyboard shortcut to open the program. It's a seriously useful trick, especially if you don't want to stuff your taskbar full of quick-launch program icons. Don't forget to click OK when you're done to save the shortcu
Computers & Internet Logo
how do i add gmail icon to task bar
What version of windows are you using? Windows 7 you can create a shortcut to your gmail account on the desktop. Download and save a Gmail Icon file (should be .ico from somewhere like http://findicons.com/search/gmail) then right click on the newly created shortcut on your desktop, choose properties, choose change icon under the shortcut tab, browse to where you icon was saved when you downloaded it and click on the file [your shortcut icon should now display your new icon]. Next click on your desktop shortcut holding your right mouse button and drag it to your task bar and release the right mouse button when pin to task bar is displayed.
Jan 19, 2015 | Computers & Internet
Hi, I have USB keyboard and I installed PS/2 optic mouse to my PC. Mouse doesn't work .i have windows 7 ultimad 32 bit and MB DH55TC intel i am changin my optic mouse by roll mouse and again dont work but when i shutdown pc the roll muose work and when restart pc the roll mouse dont work again
click start control panel view devices and printers you should see your mouse right click mouse you could open it and then select configuremy mouse or select settings then hardware make sure you have the correct mouse selected also right click on the mouse select properties to make sure you have the correct mouse right click on mouse you can troubleshoot this will activate the troubleshooting for you
hope this will help
Jul 23, 2011 | Computers & Internet
how do i get rid of magnifier?
If you installed the software that came with your mouse, there will be a shortcut on your desktop to the microsoft wireless laser mouse configuration. Double click on this shortcut. In the window that opens, at the very bottom, there are options for both the left and right side buttons. In the drop down window, select "Disable" for both. Click on "Apply" Click on "Okay" or "Close"
Oct 03, 2009 | Microsoft Wireless Laser Mouse 5000
Changing Sensitivity
1. Open the SetPointTM software and assign a keystroke to the button you want to use. For further details about this procedure, launch the Help Center within SetPoint and view the mouse topic To change the task assigned to a button. 2. Click the Windows® Start button, locate the function or application you want to launch and right-click it to display a menu. (If the function or application you want to launch is not available from the Windows Start menu, use Windows Explorer to locate it and then right-click it.) 3. Select Properties. 4. In the Shortcut tab, enter a Shortcut key that is the same as the keystroke you chose at step 1. 5. Click OK.
Oct 06, 2005 | Logitech MX1000 Laser Cordless...
689 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
