Tip & How-To about Microsoft Computers & Internet
More secret right-click options
Secret right-click options revealed by the Shift key don't end with file paths, though.
The basic Send to tool that appears as an option when you right-click on a file or folder is handy enough indeed, allowing you to move the item quickly to a handful of locations on your PC, add it to a .zip archive, or send it off in an email or fax.
But that's just the tip of the iceberg! Holding down the Shift key as you right-click a file or folder will add an absolute ton of new folder locations to the basic Send to menu.
Computers & Internet Logo
IE command bar missing customize on View/Toolbar menu
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list Managed add ons Toolbar extensions Search providers and Accelerators you have if don't need any of them you can disable or remove them. Right click in the bottom toolbar (Bottom of Screen) select the toolbars option then Desktop this will add >> arrows in the bottom toolbar select the arrows you will see a list with control panel which has another list of all control panel items
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar. This will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text s largest to smallest b> b> Right click the toolbar at the bottom of your screen. Click "Properties." Check the "Auto-Hide" option. Click "Apply." This will minimize your toolbar. To reveal your toolbar again, move your mouse down to the bottom of your screen. This will reveal the toolbar for as long as your mouse is in this location.
Apr 01, 2013 | Microsoft Internet Explorer 9
system disks startup
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Nov 12, 2012 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
I wish to keep the yahoo account but I don't want it to show on my home page. Can this be accomplished?
When you say homepage I assume you don't want to load yahoo site whenever you open a web browser. TO change your web homepage you need to go to the following:
for Firefox 6.01. (Most likely all firefox ver. are similar)
- Click tools
- Click Options
- Go to General TAB
- type the website you want to be on your homepage at HOME PAGE box or Start page for other version
For Internet explorer 8 (other version are similar but not identical. Just look for tools)
- Click tools
- Click Internet Options
- Go to General TAB
For Google Chrome
- Click the wrench icon on the top right side
- Click options
- Click Basics
- At the HOMEPAGE section type in the website you want to load
Basically thats all. Please note browsers has different version but always look for the tools menu
Sep 05, 2011 | Yahoo Mail
I want to unstall Nancy Drew
unfinished. hope it still helps!!option 1: well, right click on icon, then click: open file location, you might see something with part of the word 'uninstall' and note that it might be like this for example: unins0000.exe or it might be in a folder then click on it it should say installing now when it says that it means it's using installer to uninstall it so don't think it's reinstalling.
option 2: go to start menu, click control panel, click on 'programs' and/or 'programs and features' and you should get to a list of programs installed select the game click uninstall.
option 3: right click on icon, then click: open file location back up a folder ( doesn't mean press the back button depending on the operating system being used here are instructions for xp, vista,7.
xp:backup button-->cmputergeek.jpg
vista:
7:
Jul 11, 2011 | Her Interactive Nancy Drew: The Secret of...
what is the computer key
Hi Good day!! Here are some basic key for computer..
Alt + F File menu options in current program.
Alt + E Edit options in current program
F1 Universal Help in almost every Windows program.
Ctrl + A Select all text.
Ctrl + X Cut selected item.
Shift + Del Cut selected item.
Ctrl + C Copy selected item.
Ctrl + Ins Copy selected item
Ctrl + V Paste
Shift + Ins Paste
Home Goes to beginning of current line.
Ctrl + Home Goes to beginning of document.
End Goes to end of current line.
Ctrl + End Goes to end of document.
Shift + Home Highlights from current position to beginning of line.
Shift + End Highlights from current position to end of line.
Ctrl + Left arrow Moves one word to the left at a time.
Ctrl + Right arrow Moves one word to the right at a time.
Don't forget to vote thanks!!!
Oct 29, 2010 | HP Computers & Internet
631 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
