Tip & How-To about Cell Phones
How To Unlock iPhone 2G, 3G, 3GS, 4, 4S, 5, 5S, 5C, 6, 6+, 6s, 6s plus
Insert a non accepted SIM card in your iPhone.
(Ex. If this phone is locked to AT&T, we are inserting a T-Mobile Simcard)
Keep in mind, the iPhone 5 requires a Nano SIM card!
If your iPhone is carrier locked, you will see message "activation required"
"Activation Required". This means the Non Accepted SIM card is not
working because your iPhone is locked.
Also you will notice there are no Signal Bars being displayed.
1) Start your iPhone on with a non accepted sim card. The message " Activation Required" will come up.
2) Now on your computer, open iTunes make sure it is updated to latest version.
3) Now you connect your iPhone to your computer
4) Your iPhone should automatically go to the Home screen and you should start to see signal bars from your new carrier
5) "Congratulations, your iPhone has been Unlocked" message will appear on your iTunes if Unlocking is successful.
If you have any questions or need help please let us know.
Cell Phones Logo
how can you fix sim lock on an iphone?
Make Sure your iPhone asking for sim unlock code after insert a non accepted sim card( For Ex. if you are using AT&T sim insert the T-Mobile sim in this)
If yes then follow the steps below:
go to the www.unlockninja.com and select as per your requiremnet
Brand Name:-
Model No or Name:-
Country from The Phone Purchased:-
Network on which The Phone Is Locked:-
Mail ID:-
place order to unlocking confirmation at https://www.unlockninja.com/unlock-apple+phone and wait for the giving time that is 30 min to 2 days
You will confirmed via mail as the phone has been unlocked. Then you only need to follow the steps below:
How to fix sim lock in apple iPhone
How to Unlock the Apple iPhone 6 after getting the confirmation as Unlocked
-Install the last version of iTunes on your computer.
-Make sure your iPhone is updated with the lastest version of iOS.
-Switch ON your iPhone 6 with a SIM Card from a non-compatible network.
-Connect your iPhone 6 to your computer using the Original USB Cable.
-Launch iTunes andwait until iTunes detect your iPhone 6.
-Now disconnect your iPhone 6sand reconnect it after 10 seconds.
-Your iPhone 6 is now Unlocked!
Note:-In the unlikely event that your iPhone 6s is not unlocked, please restore your device following the official guideline from Apple - https://support.apple.com/en-us/HT201252
Mar 09, 2017 | Apple iPhone Cell Phones
insert sim
What is your mobile model?To insert simcard,the following conditions should be satisfied....
1)The mobile should be unlocked to accept the sim card
2)The mobile should have the sim slot (most CDMA phones do not have that provision)
3)The simcard size should be supported by mobile phone.
Now,if your mobile is locked with a particular network then you need to unlock it.For that you can either approach the respective network provider or third party unlocking services like Simpleunlocking.com or unBBlock.com (This is specifically for Blackberry phones) and unlock your mobile.Once your mobile is unlocked the sim slot will either be in the side or above or below the battery depending on your mobile model.If you search in Google you probably will get a more clear idea about where your sim slot is located.Once you find the sim slot remove the sim card and note down the position; replace it with the old sim card(it should support the phone sim size specification).
Jul 12, 2013 | Cell Phones
my phone is N95.it shown the offline mode bt when i changed the profile and select the general profile after that it does not work.pls help me how i can open my phone lock..........
This is not a lock.This problem occurs when Sim card IC is damage,Sim Case damage.But one thing you can try is Clean the sim Case and Sim card.Insert the sim and switch in the phone .If the problem still persist Contact mobile repairing shop.Good luck Thanks
Jul 25, 2011 | Nokia N95 Cellular Phone
i phone no sim
try removing the simcard from the iphone by inserting the end of a paperclip into the small hole at the top of the i-phone, this will push out the simcard. Then clean the simcard and re-insert it into the phone, the issue should now be resolved. if it persists then it could be because you have a faulty simcard in which case take your i-phone to your nearest apple/o2 store and they should give you a replacement.
Feb 24, 2008 | Apple iPhone Smartphone
simcard problem
free diagram
Dec 29, 2006 | Nokia 7610
693 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
