Tip & How-To about Schwinn IC2 Indoor Cycling Bike
How to level your indoor cycle
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Video about Leveling Your Indoor Cycle
  • This video is going to demonstrate how to level your indoor cycle to compensate for uneven surfaces
  • Tools needed:
    • Adjustable Wrench
  • First tilt the bike from side to side to figure out which leveler should be adjusted
  • Then tilt the bike onto the handlebars as shown in the video
  • Now you can adjust the appropriate leveler to make the correct adjustment
  • To do so first loosen the lock nut and then spin the leveler up or down, depending on the adjustment needed
  • Now tighten the lock nut back down and stand the bike back up
  • Check the bike again for excessive side to side movement and repeat the process as necessary
  • This concludes our demonstration of leveling your indoor cycle
Video Demonstrating How to Level Your Indoor Cycle
Schwinn IC2 Indoor Cycling Bike Logo
display showing strange symbol
This is common for a bad display board. The only resolution to this problem is to replace your display electronics or the console as a whole.
Feb 13, 2014 | Life Fitness Lifecycle GX Indoor Cycle
270 people viewed this tip
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
