Tip & How-To about Philips Screeneo HDP1590
Philips short distance projector pinout AV cable composite video kurzdistanz beamer
Hello all,
I am going to talk about the sufficiently nice Philips HDP1550 short distance projector (German: Kurzdistanzbeamer), but in this regard it should be identical to this existing HDP1590 product entry.
The pinout of the AV audio video composite cable output of these projectors (to be used to connect DVD players etc.) AFAICS is NOT documented in the manual (hmm...), and there is a cable offered by Philips which can be bought as an optional item.
However I was able to identify the pinout / connections properly, and a cable I bought does work fully properly on the HDP1550 (i.e. both video output nicely working *and* Left / Right properly assigned). :)
Text as printed on the label of the white plastic bag:
Model: POPPSTAR
Poppstar Audio/Video Kabel 3.5 mm
Klinke Stecker auf 3x Cinch AV/TV 4-polig
Camcorder Digitalkamera
Art-Nr: 1004152
[Product No.]
Bar code 4260209263989
[RoHS CE Recycling NOT-TO-Wastebin]
INCOMPATIBILITY WARNING: pinout of such AV cables (*from* 4-pin audio jack / phone plug *to* 3-line RCA / cinch connectors) is wildly differing since NOT properly standardized / declared, thus it is important to buy the correct one (or alternatively multiple cheaper cables in order to have some spares for the correct combo).
Oftentimes one can only *try* buying the correct one since pinout is not properly declared (or even sometimes reported to still differ between product declaration and item shipped!!).
Note that a cable you own which is *incompatible* can still be tested / deployed: by plugging the jack *not completely* into the output (thereby hitting *other* rings and thus re-assigning connections!).
That way one is able to figure out any unknown pinout and thus know to buy a correct / matching / compatible cable then.
The pinout of the AV cable output of HDP1550 thus is:
A widely used terminus technicus of this type of 4-pin jack connectors is "TRRS" ([T]ip - [R]ing - [R]ing - [S]leeve, as seen as the physical design of the audio jack):
Connection: Tip - Ring - Ring - Sleeve
Signal: R - L - AUX (Video) - GND
This pinout AFAICS thus is *almost* equivalent (except for Right / Left being swapped) to the pinout that is specified by the "OMTP" standard, thus cables following OMTP standard can be used (but note that Right [Red] / Left [White] RCA connectors should then obviously be *swapped* with such a cable pinout, to achieve proper assignment).
Note about known 4-pin "audio jack" standards:
CTIA: L - R - GND - AUX
OMTP: L - R - AUX - GND
BTW, there are converter cables / adapters available to convert between CTIA and OMTP (e.g. Adaptare GmbH).
=== begin INCOMPATIBLE cable example ===
AVK199-150
Bar code 4 040849 502095
T - R - R - S
L - AUX - GND - R
(i.e., NOT compatible, with neither CTIA nor OMTP!)
=== end INCOMPATIBLE cable example ===
That article should now have managed to describe almost everything that there is to describe about such cable types :)
HTH & HAND
Andreas Mohr (Linux user and developer)
Philips Screeneo HDP1590 Logo
When I turn on projector,image on screen is backwards. How can I fix that.
Look in the setup to see where you select from rear projection to front projection.
Mar 11, 2016 | Office Equipment & Supplies
VGA Cable max Length from Laptop to Projector
Your on the edge, possible that the image will be unstable (wiggly). Considered a VGA amp from Gefen to up the drive. 50ft is about max. You can try dumbing down the res if it is unstable. Less horizonal frequency to travel long distance. good luck
Jun 03, 2009 | Philips cBright XG2 Multimedia Projector
298 people viewed this tip
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
