Tip & How-To about Miscellaneous
How to get rid of NTLDR
Get a Windows 7 installation disc.
Miscellaneous Logo
reset windows 7 password hp
You may try the below steps to reset or recover the windows login password:
1) Insert either your Windows 7 installation DVD, or a Windows 7 System Repair disc, into your optical drive and then restart your computer. If you have either on a flash drive, that'll work too.
Note: If you don't have original Windows 7 media and never got around to making a system repair disc, don't worry. As long as you have access to any other Windows 7 computer (another in your home or a friend's will work fine), you can burn a system repair disc for free.
2) After your computer boots from the disc or flash drive, click Next on the screen with your language and keyboard choices.
Tip: Don't see this screen or do you see your typical Windows 7 logon screen? Chances are good that your computer booted from your hard drive (like it normally does) instead of from the disc or flash drive you inserted, which is what you want. See the appropriate link in the tip from Step 1 above for help.
3) Click on the Repair your computer link.
Note: If you booted with a system repair disc instead of a Windows 7 installation disc or flash drive, you won't see this link. Just move on to Step 4 below.
4) Wait while your Windows 7 installation is located on your computer.
5) Once your installation is found, take note of the drive letter found in the Locationcolumn. Most Windows 7 installations will show D: but yours may be different.
Note: While in Windows, the drive that Windows 7 is installed on is probably labeled as the C: drive. However, when booting from Windows 7 install or repair media, a hidden drive is available that usually isn't. This drive is given the first available drive letter, probably C:, leaving the next available drive letter, probably D:, for the next drive - the one with Windows 7 installed on it.
Hope this helps..
Feb 18, 2015 | HP Computers & Internet
asus 53 n laptop
1. option - Removing Windows 8 by installing Windows 7 over it*:
Go to the disc where you have the Windows 7 installer.
Then right click, click on Mount, when done, click on the Setup file and install Windows 7 over your current system.
2. option - Keeping Windows 8 and installing Windows 7 alongside it**:
Restart the Windows 8 system, before Windows logo shows up, keep pressing F12, then choose the disc you have Windows 7 .iso file on.
3. option - Running it from a DVD, but keeping/removing*** Windows 8:
a) go to the disc where you have the Windows 7 .iso file installer.
b) move the .iso file to a easily accessible place like Desktop.
c) then right click on the .iso file and click on Burn disk image, choose the DVD you want to boot from ( You need a readable DVD), and then check the checkbox which says " Verify disc after burning ".
d) click on Burn.
e) when that is done, close all open programs or/and windows and restart your computer, before Windows logo shows up, keep pressing F12, then choose the disc you have Windows 7 installer on.
Note - please read everything carefully. I suggest you to use the 3. method.
* - when in the setup, you have no option to go back to Windows 8.
** - this step might not work, because not all computers support that.
*** - you can choose to either create a new partition on which you will install Windows 7 or install it over Windows 8 by either kepping or not keeping your personal files.
Please reply to this solution: did it help you or not and what improvements in my solutions do you want, and rate my solution from 0-5.
Jan 12, 2013 | Computers & Internet
how to install windows 7 operating system
To Install the Windows 7 Operating System (Win 7 OS):
Instructions for a "Clean/New Windows 7 Installation:
AFTER BACKING ALL YOUR DATA THAT YOU DON"T WANT TO LOSE, Do the Following :
1) Insert your Genuine Windows 7 System Disc (Retail or OEM System Installation Disc).
2) Close down all programs and restart your computer.
3) As soon as the computer restarts, you should see a prompt that says something like this: "Press any key to boot from cd/dvd"
....So press any key!... This will boot to the installation disc and prepare for installation or repair (we are going to be installing windows, so ignore the repair options you see on the screen).
*If you don't press a key in time, you will see that the computer will attempt to boot from the hard disc drive instead... if that happens, restart the computer and press a key when prompted.
4) Depending on your particular Windows Version, you will see a prompt that says something about "Do you accept the license terms?" Click "Yes" or "I accept", etc.. and continue on...
5) Choos Custom or Advanced Settings (the other option is for an upgrade..)
6)Select the desired hard disc drive, (HDD aka Hard Drive), Select "Drive Options", and follow the onscreen instructions "Delete the partitions" (Do not Leave another windows installation on the same hard disc drive, unless you are experienced and know how to "dual-boot" properly!) Delete the Partitions.
7) Now choose to install windows (be sure to select the newly deleted empty (unformatted) partition. Windows 7 will automatically format the drive for you and will begin to install windows 7. Follow the onscreen instructions and within a half an hour or less (depending on your hardware) you will be finished, just be sure not to leave the computer unattended while performing a windows installation, since it requires your input quite often to proceed.
That's pretty much all there is to it!.. if you have any more trouble...
Google it or Bing it.... Search Engines are awesome!.... Enjoy!
*NOTE- If your windows 7 disc is a "Upgrade" disc, then you must perform an upgrade while running your previous/older windows version, since Windos Upgrade Discs aren't bootable, they simply patch the older version, replace system files, etc... to transform the previous windows installation into the target/newer version. If you want to perform a clean install, be sure you own a Windows 7 Installation / System Startup Disc.
Jul 06, 2010 | Intel Motherboard
46 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
