Tip & How-To about Miscellaneous
Engine will not crank
If your vehicle is a few years old, or older, and you go out to start it and the motor won't crank try this easy solution. Remove both battery cables from the battery and take a piece of sandpaper cleaning the posts and inside of the cables. There is a good chance corrosion is keeping the cables from making good contact. Simple solution that may work, and worth a try before starting major diagnostics.
Miscellaneous Logo
2003 suburban has been siting for 3 years and now won't start. I can hear fuel pump working when key is ON. Battery is charged. What could it be? It cranks over like no fuel or spark getting to it
If it's been sitting for 3 years I would do as follows
1. Drain tank of all gas, give it some fresh gas.
2. Change the Spark Plugs
Attempt to start it. (Keep in mind it may take a few times to get all that old gas out of the lines)
Sitting it the worst thing for a rig. I advise never let it go without starting it ATLEAST once a month
If that doesn't work make sure it is getting fuel to the motor.
If so it could be your Distributor or Coil. Good luck
Mar 24, 2013 | 2003 Chevrolet Suburban
Car won't start without a jump but battery okay
wont crank or wont start.??
no car starts , if it cant crank. (unless push starter (M/T magic)
that is not a trans sensor its the PRN switch.
ill answer for, wont CRANK !
it wont crank even with a good battery (charged) or jump started.
1: bad start
2: bad wires to same.
so hot wire the starter small wire, the key start line is tiny.
cranks. , starter good, no crank starter bad or cables bad.
if it cranks hot wired, then the key line is dead.
easy, huh?
Feb 11, 2013 | Suzuki Forenza Cars & Trucks
1998 Honda Accord Won't Start
Park neutral safety switch maybe be the reason for the no crank ! Try putting the vehicle in park ,then try to crank the engine . Testing the electrical circuit is the best way to trouble shoot this problem , along with do a voltage drop test on the starter circuit ! This will test the battery cables an connections .
Starter Voltage Drop
How to voltage drop test starter motor circuit
Does it have a manual or automatic transmission ? Manual ? clutch switch . Looking at a wiring diagram I also see a starter cut relay !
http://www.bbbind.com/free_tsb.html Free wiring diagrams . Enter vehicle info. year , make , model and engine size . Under system click engine , under subsystem click starting . Then click the search button , then click the blue link ! Check the starter cut relay also . Videos on youtube showing how to test a relay controlled circuit !
May 29, 2017 | 1998 Honda Accord
2000 olds alero cranks then makes a metal grinding sound and won't start
You need to have your flywheel: replaced.Your starter motor engages against the fly wheel at the back of the motor. Every time your motor stops it tends to be in the same few positions (just the way things work) so there is more stress on some parts of your fly wheel than others. Because of this the teeth wear out on the fly wheel which means the starter can correctly engage on the fly wheel which is the grinding noise.
Jan 18, 2013 | 2000 Oldsmobile Alero
1978 super beetle won't crank. battery good. turn key, hear faint humming sound, nothing from engine
think you may have a faulty starter motor here ,this year vehicle will be of the pre engaged type so no seperate heavy duty solonoid unlike older cars ,i would expect a click of the solonoid and nothing if the starter has burnt out but its possible that the solonoid on top of the starter has failed but without a look myself and only a description i cannot diagnose correctly .Try some jump leads just to be sure it isnt a flat battery then check the engine earth to chassis cable then remove the starter motor and have it checked out
Aug 04, 2012 | Volkswagen Beetle Cars & Trucks
84 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
