Tip & How-To about Skin Care Health & Beauty
How To Remove Blackheads From Nose?
Here are some home remedies for remove black heads from nose...
1. Baking Soda
Baking soda is an effective treatment for blackheads as well as acne. It helps clear the skin of impurities such as debris and dirt.
  1. Mix two teaspoons of baking soda with mineral water to make a paste.
  2. Apply the paste generously on the affected skin area and massage gently. Allow it to dry for a few minutes before rinsing it off with warm water.
  3. Repeat this remedy once or twice a week.
2. Cinnamon
Cinnamon can be used to remove and prevent blackheads
  • Mix one teaspoon each of cinnamon powder and lemon juice with a pinch of turmeric powder (optional). Spread it on your face, leave it on for 10 to 15 minutes and then rinse it off.
  • Alternatively, mix one teaspoon of cinnamon powder and honey to form a thick paste. Apply it on the affected area before bed and leave it on overnight. In the morning, wash your face well with normal water. For best results, follow this remedy daily for about 10 days.
3. Oatmeal
The combination of oatmeal and yogurt is great for keeping your skin free of blackheads.
  1. Mix one teaspoon honey and the juice of four tomatoes in sufficient oatmeal to make a paste.
  2. Scrub it on your skin.
  3. Wash it off after 10 minutes.
  4. Repeat regularly for clear skin.
You can also make a paste by mixing together two tablespoons of oatmeal, three tablespoons of plain yogurt, and small amounts of lemon juice and olive oil. Apply the paste to your entire face, leave for a few minutes and then rinse your face with water.
Health & Beauty Logo
What are dermal fillers meant for?
We present you six natural ways to help you get rid of blackheads:
1. Baking soda removes blackheads
Ordinary baking soda is at least as effective with blackheads as so many expensive branded products from the drugstore. As you can remove blackheads with soda is quite simple!
Make a paste with the soda: For this purpose, a teaspoonful of baking soda is mixed with two teaspoons of distilled water. Then the paste is applied to the affected skin part, thoroughly massaged and rinsed. This procedure not only removes dead or damaged skin cells but also removes the dirt and excess oil that blackheads cause at first. Do not use the usual baking soda to remove the blackheads, but only pure soda.
Aug 29, 2013 | Andalou Naturals Deep Wrinkle Dermal...
Are there any at home remedies to making my own dog shampoo?
Believe it or not, baking soda is your solution. Simply sprinkle some baking soda onto your dogs coat and rub it in with your hands. The make sure to give your dog a good brushing. Baking soda is great because it is inexpensive, will not irritate your dogs skin and it neutralizes odors.
Aug 15, 2012 | Pets - Others
How clean oven??
  1. Buy an empty spray bottle and some baking soda.
    You'll find that baking soda is cheap -- especially if you buy in bulk.
  2. Using a funnel, place 3 heaping teaspoons of baking soda into the spray bottle.
    If the baking soda clogs the funnel, unclog it with water.
  3. Wash the baking soda into the spray bottle by running water into the funnel.
    Fill the bottle with water. After the bottle fills, you'll notice undissolved baking soda that has settled at the bottom of the bottle.
  4. Shake the spray bottle so that all the baking soda dissolves in the water.
    Unless all the baking soda is fully dissolved, some of it gets left behind in the bottom of the bottle as a residue.
  5. When the oven is cold, spray the baking soda and water solution on to the black stuff. Do this one or more times a day.
    It is important to work on a cold oven for two reasons:
    • Safety. You can't burn your hands if the oven is cold.
    • Containment. You'll get baking soda all over the house if you start with a hot oven. I know. I've done it.
      Starting with a cold oven solves the problem.
  6. Use your oven as you normally would. Keep spraying wet baking soda on to the top and sides of the interior of the oven between meals.
    Wet baking soda will break up the carbon sticking to the sides of the oven. Keep spraying baking soda on to the black stuff between meals until it is all gone.
    Don't worry about getting baking soda in your food. Baking soda is one of the prime ingredients of many recipes such as corn bread. It is safe to add it to your food should you do so inadvertently.
    Using this technique, the black carbon that was stuck to the sides of your oven will flow to the floor of your oven and settle there as a black carbon powder that can be wiped away.
    Your oven will look like a mess while this is in process. Choose a good time to do this.
  7. At your convenience, when the oven is cold, wipe your oven with a damp cloth.
    Eventually, you will have to wipe down your whole oven with a damp cloth. The black carbon and baking soda will will settle together on the bottom of your oven. Both are easily removed with a damp cloth.
    In theory, you will have to apply the spray bottle many times but you should only have to wipe down your oven once. Try not to wipe down the oven prematurely as this removes the active ingredient that makes the whole thing work -- the baking soda.
    Important! Let the baking soda accumulate so that it can do its job.
  8. Repeat, repeat, repeat until all the black carbon is gone.
Nov 10, 2008 | GE Kitchen Ranges
350 people viewed this tip
