Tip & How-To about Computers & Internet
How to choose a budget Wi-Fi Router?
How to choose a budget Wi-Fi Router? What models are the best in terms of price and quality? Does it make sense to overpay for the brand? What the signal power is enough and what other settings should pay attention to? What is better: Wi-Fi router with internal or external antennas and how to install right it in your home or flat? The answers to these and other questions in the article below, and the best budget Wi-Fi routers of this year - at the end of it.
The choice of the manufacturer
All modern Wi-Fi routers are highly integrated devices. It is thought that they are reliable and broke quite rarely. Recently, the Taiwan company which makes D-link and other good-quality goods, was a monopolist on the market, but several years ago, the Chinese TP-Link had dislodged it, which makes even better goods by all features. The solid ZyXEL is very popular, it's reliable, but unreasonably expensive.The same situation is with Asus routers, which are popular now. To gain the market, beginners try to lower the price on their devices, but without sacrificing quality to do it below the level of the TP-Link is impossible.
So what manufacturer to choose? The survey is available Internet providers and my own experience agreed that for flats, houses or small office perfect ratio of price and quality are 2 mass models of TP-Link, review on which are listed at the end of the this post; fans of the classics can choose D-Link, but experimenting with little-known or unknown manufacturers to save 2-5 $, at least is unwise.
It must be noted that the most common cause of failure of any router is a stroke of lightning (this happens most often in the private sector in May-June), so it is advisable to put a lightning protection (WAN port) at the input. To buy expensive models makes no sense, because in most cases, a regular cheap surge protector without earth ground is able to cope with 98% of other discharges and the direct impact of the storm still will not leave a chance to survive even to a very cool router. By the way, for the same reason (risk of kick thunderstorms) preferably all clients (especially expensive SmartTV, PCs and laptops) to connect it wirelessly, as in the case of lightning strike or strong interference on the input WAN port you run the risk of losing only a cheap router, but not all your connected equipment..
Define with Wi-Fi router characteristics
1. Customer primarily pays attention to the speed connection, although this is a very deceptive feature. In theory, the maximum speed of the budget Wi-Fi routers is 150 Mbps (megabits per second), at the same time, just a few providers can offer just 50 Mbps, so it becomes clear that the alluring phrases like "up to 300 Mbps" or even "up to 1300 Mbps", in fact, means that when you work in the Internet the speed difference between the expensive and cheap Wi-Fi routers will not differ a lot.
2. Radius of action. It seems to be easy, because, as usual, to specify the distance outside and inside the premises, everything is clear and understandable. But these values are very relative, especially indoors, as a couple of good reinforced concrete walls will negate the signal of even the most powerful router, so really important are the two following characteristics.
3. The transmitter power - the name speaks for itself and it is really important. Most of the budget routers have a transmit power of about 17 dBm, or even less, which is usually enough to more or less confidently "break" in only 2 walls. It worth noting, that some Wi-Fi routers have the technical ability to operate at much higher power (typically up to 27 dBm, 500 mW), so they are in accordance with local regulations artificially reduce its capacity.
4. Antenna gain power confuses many users into believing, as in fact, antenna is a passive device and does not amplify anything themselves, they can more narrowly direct signal. For example, the higher the antenna gain, the more power the transmitter out to the sides, and the less energy transmitter goes up and down. Thus, a more powerful antenna is not a universal solution, because it allows you much more "punch" in the signal, but the "taking" of its top and bottom.
5. The number and types of antennas. When you use multiple antennas, their energy does not stack, so it will not allow you to "punch" more the number of walls, but only make the connection more stable. The difference in coverage of routers with one antenna and two antennas is significant, but the difference between 2 and 3 antennas is almost non-existent, the last one is useful only when the signal must be passed between floors. To cover as much room as possible one-story house or apartment, you need to install the antenna vertically or at a slight angle relative to one another. Built-in antennas have a little gain, so the can spread the signal is uniformly in all directions and can be extremely helpful in smaller spaces. It is recommended to buy a wifi router with 2 antennas and with the gain greater more than 5 dBi for a regular signal in a one-story house or apartment.
The best budget Wi-Fi routers of this year and more about them you can look here:
http://www.gadgetreview.com/best-wireless-router-for-home-gaming-mac-overall-2015-2016
http://www.bestadvisor.com/electronics-computers/best-wireless-routers
http://www.tomsguide.com/us/best-wifi-routers,review-2498.html
http://www.pcmag.com/article2/0,2817,2398080,00.asp
Computers & Internet Logo
Carnot connect to wifi
Make sure the router is working as it should.
Mar 19, 2017 | Cell Phones
Tips for buying Aviator Sunglasses for Men. 1. Budget Budget is the most important driving factor before you go out to own your dream pair of sunglasses. How much would you like to shell out for the pocket, plays a vital role in buying a pair of pilot sunglasses. If you are a bit apprehensive about your budget, then trying searching on the internet or some local the departmental store nearby. However, be ready to compromise on the quality of the shades; or rather go in for a well-known brand for the best quality if budget is not a constrain. 2. Brand - the Key Factor As mentioned in the above point, if price is not a matter of concern and you are the kind of a person who wants only the best, then brands such as Gucci or Ray Ban is the right choice for you. You can be rest assured that these brands will offer you the best quality of shades. Don't be surprised if the price tag attached to the pair of pilot shades which you desire reads around $200. Although the price tag may look a bit too heavy, at the end of the day it is definitely worth the brand value. 3. Opt in for a polarized or non-polarized pair of lenses These Aviator shades come in two different options - with or without polarized lenses. Polarized lenses do a great deal in further reducing the sun's glare, while the shades with non-polarized pair of lens can relatively block lesser amount of glare. However, the polarized lenses are a bit more expensive when compared to the non-polarized lenses.
Nov 07, 2010 | Clothing Accessories
Is either an N router or AC wifi router compatible with a Gateway NV54 laptop running Windows 7? My old G router is dead & need to buy new one.
Linksys is a good router that will automatically switch based on your devices. They run about $150. Is that out of your range?
I would suggest Linksys - AC1200 Smart Wi-Fi Router
Jun 18, 2015 | Gateway Computers & Internet
How can I lock my Wi-Fi?
You will need to read your owner's manual or look up the model of your router and find it's Setup IP Address. After doing so, you may need to enter a username and password. Unsure of what this may be, usually the username is "Admin," and the password is "password" in lowercase letters. You will need to choose your "Security" settings, and click on WPA option which will allow you to enter a password of your choosing. The router will reboot, and you will have to reconnect to your router using the correct pass phrase in which you have chosen to secure your Wi-Fi connection with.
If this has helped you, please, let me know. If not, I will do my best to further assist you.
Nov 16, 2012 | Computers & Internet
hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
879 people viewed this tip
David Payne
David Payne
