Tip & How-To about Miscellaneous
Declogging a showerhead
  • Put some White Vinegar into a plastic bag,making sure it is deep enough to cover the showerhead.Place sh'head in the bag,close top with a tie and leave overnight.You can also use the solution to descale kettles.
Miscellaneous Logo
Any idea how to open the grey part where the water comes out of this rohl 1151/8pn handheld shower?
Joe, Soak that head in a plastic bag or container of vinegar and it will remove most if not all the deposits, just give it a little scrub with old tooth brush a few times put back in vinegar for approximately 4 hours or leave overnight. This may also allow easier disassemble.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Top 3 Tips For Cleaning Your Shower Head
How to Clean the Showerhead with Vinegar
Tie Bag of Vinegar Around Your Shower Head to Clean It with No Effort
How to Clean Your Shower Head Easy Bathroom Cleaning Ideas Clean My Space
May 26, 2016 | Rohl Home
How can I remove a kitchen faucet pull-down sprayer head?
clean the head with out removal, place head assy in large jar or bowl and add straight vinegar enough to cover head for 1 hour then with a toothbrush , brush away residue and repeat process a couple times, usually works great for me.
press the helpful button
How to Clean Clogged Showerhead Today Homeowner
Jan 14, 2016 | Plumbing
How do I take apart a moen shower head?
You can remove the head from the shower arm by taking a crescent wrench. Put it on the flat sides of the nut on the showerhead and unscrew it counterclockwise. There is no way to take apart the Moen showerhead. If the reason you want to disassemble the showerhead is to clean it because it is clogged, disassembly is not needed. Just fill a Ziploc bag with a 50-50 solution of vinegar and warm water. Place the bag onto your shower head so it is fully immersed in the solution. Use a rubber band to hold it in place. Let it soak overnight and then take a toothbrush to any of the white scaly matter that might remain.
Aug 10, 2015 | Moen Home
How do you unscrew Hansgrohe showerhead (needs cleaning to remove calcium deposits)?
Easiest is to simply pour some CLR cleaner (from grocery or hardware store, it is a brand name) into a plastic bag, and tie the bag around the pipe with the shower head soaking in the solution.
Easy fix!
Jul 26, 2014 | Hansgrohe Home
The shower head is clogged how do I clean it?
get some CLR which is calcium lime and rust remover.Unscrew it from the pipe on the wall with the water off and pour it where the water flows into the head and wait for it to drip out the jets.
Apr 21, 2009 | Grohe 28 783 000 Rainshower Jumbo...
85 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
