Tip & How-To about Miscellaneous
Super Glue & Baking Soda
A dash of baking soda will instantly harden super glue.
Miscellaneous Logo
recipe for oatmeal cookies
Oatmeal cookies
Makes 20 cookies 1 cup (2 sticks) unsalted butter, softened
1 cup granulated sugar
1/2 cup packed brown sugar
1 large egg
2 teaspoons vanilla extract
1 2/3 cups all-purpose flour
1 teaspoon ground cinnamon
dash of nutmeg (optional)
dash of ginger (optional)
3/4 teaspoon baking soda
1/4 teaspoon salt
1/8 teaspoon baking powder
1 1/2 cups quick cooking oats
Preheat oven to 350 degrees F. Line 2 large baking sheets with parchment paper or spray with non stick spray.
In a large bowl with an electric mixer, beat butter and both sugars until fluffy. Mix in egg and vanilla until well blended. Combine flour, cinnamon, nutmeg, ginger, baking soda, salt, baking powder and in a bowl. Stir into butter mixture. Gently stir in oats until well blended.
Shape dough into rounded golfball-sized balls (about 2 Tbsp. each). Place on prepared baking sheet . Flatten with the bottom of a measuring cup dipped in sugar.
Bake for 8-10 minutes. Let cool on baking sheet 5 minutes before removing to rack to cool completely.
Oct 22, 2016 | Baking
I have a cracked fuel tank which I tried to fix but it still leaks. Would this affect the carb adjustment as I can't seem to keep the engine running unless partially choked.
No shouldn't affect that. Try using a mixture of super glue and baking soda smear it on and press into crack I have had good luck with this when many commercial products failed.
Sep 29, 2010 | Troy -Bilt String Trimmer/Blower...
need directions to clean my tappan oven
1. Add baking soda to a cool oven. Sprinkle a thick layer of baking soda onto the bottom of the oven. Make sure the oven is completely cool before you attempt to do this. 2. Spray the baking soda with water. Using a spray bottle, spray the baking soda down until it is damp, not saturated. The water and baking soda together will help break down the food particles. 3. Continue spraying baking soda as it dries out. Every few hours spray the baking soda down again to keep it moist. Continue this process over several hours, spraying water as the baking soda begins to dry out. 4. Scrape out the baking soda. Scrape the baking soda out of the oven. Food residue will be scraped out with the baking soda. 5. Rinse the bottom of the oven out thoroughly. Yes, you'll still have to rinse out the oven, but next time you cook your food won't have an added taste of oven cleaner.
If I had the rest of your model number I may find what Tappan now Fridgedaire Electrolux reccomends, but this is the least toxic. Have a great day..
Feb 08, 2009 | Tappan TEF242 Electric Kitchen Range
whine in my coil
No, the coil does not get that hot, the super glue is just there to harden and stop the coils from vibrating - this is a common problem on Sony tv's too.
Jan 29, 2009 | RCA D52W23 52" HDTV CRT TV
72 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
