Tip & How-To about Miscellaneous
If your staircase rattles [wood railing] when you grab the handrail...it can be easily be fixed by.... dipping a round tooth pic in white/yellow glue, insert it between the top of the picket and the hole in the rail and push it in until it begins to wedge, then the trick! Break the toothpick but not completely, then push the toothpick deeper so as to complete the break deeper inside the rail for a clean look. Also: you can find the loose pickets/balusters by tapping the side of the rail and holding and listening as you go along.
EH joinery can help you there. They have competent staff to assist you with your needs. You can get in touch with them in their website. They are builders of staircases Doors, Gates, Windows, Timbers, Mouldings & Turnings, Timber Signage and specials for quite a long time and they know what is best in any situation. They will be happy to be of service to you. They will provide you with an estimate of what it will cost you if you have your staircase repaired or improved. It is best to get advice from the experts so that you will be ensured that what you are doing is cost effective and more appropriate for what you have in mind.
