Tip & How-To about ASUS Google Nexus 7 Tablet
Waking up nexus 7
Hi If you're Nexus 7 is a bit sluggish on first start up::: hold down the power button for 6 to 7 seconds it should reboot :: I have tried this with 2 they did operate normal after reboot....Cheers
ASUS Google Nexus 7 Tablet Logo
my nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
my nexus 7 tablet wont leave the startup screen. I tried a hard reboot but it stays on that screen and wont turn off
(enter BootLoader)
Step 6: Toggle with vol down CLEAR CACHE & reboot
Nov 03, 2013 | Google Nexus 7
My son's Nexus 7 will not power on at all...I just tried holding the power button down for 20-30 seconds, but still nothing....
In addition to holding the power button down, try holding both the power button and volume down button for 23-30 seconds and see if then the device comes up.
Hope that helps!
Oct 17, 2013 | Google Nexus 7
my nexus 7 will not turn on and its only a week old
You may want to try and do a hard reset/reboot which will hopefully bring the Nexus 7 back to life.
  1. Press the power button and both volume keys for several seconds. The computer screen will eventually blink off. Continue to hold until you see the Android recovery logo and the large Start selection at the top of the screen.
  2. Move the volume keys up and down to see the menu selections. If you don't want to factory reset, you can try to Power down or to Restart bootloader from these selections. The power key will select the option.
Hope that helps!
Mar 18, 2013 | ASUS Google Nexus 7 Tablet
Nexus 7 16gb tablet won't power on
I would do a hard reboot. To do this you should hold down the vol up, vol down, and power buttons. This should bring you into recovery mode. Others seem to be having similar issues. Warranty?
Oct 19, 2012 | ASUS Google Nexus 7 Tablet
748 people viewed this tip
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
