Tip & How-To about HP ENVY 15z-j100 Silver 15.6" Ultrabook 2.1 GHz AMD A8-5550M, 6 GB DDR3, 750 GB HDD, AMD Radeon HD Graphics, Windows 8.1, LED Backlight
HP ENVY Ultrabook 6 service manual support
Recovering using the recovery media
1. If possible, back up all personal files.
2. Insert the first recovery disc into the optical drive on your computer or an optional external
optical drive, and then restart the computer.
- or -
Insert the recovery flash drive into a USB port on your computer, and then restart the computer.
3. Press f9 at system bootup.
4. Select the optical drive or the flash drive.
5. Follow the on-screen instructions.
Changing the computer boot order
To change the boot order for recovery discs:
1. Restart the computer.
2. Press esc while the computer is restarting, and then press f9 for boot options.
3. Select Internal CD/DVD ROM Drive from the boot options window.
For more details check the link http://electro-medical.blogspot.com/
HP ENVY 15z-j100 Silver 15.6" Ultrabook 2.1 GHz AMD A8-5550M, 6 GB DDR3, 750 GB HDD, AMD Radeon HD Graphics, Windows 8.1, LED Backlight Logo
Want to put laptop back to factory settings it's a acer aspire 5359
Hi Debra
This will describe how to reinstall the Operating system on your computer.
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
To start the system recovery:
1.Restart the computer.
2.When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
3.If you are prompted with a Microsoft Windows boot screen, press the Enter key.
4.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
2.When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
3.Press the CD-ROM drive eject button and insert the disc labeled System CD.
4.Close the CD-ROM tray.
5.Refer to on screen instructions to select either CDROM or USB CDROM.
6.The computer will boot from the Acer Recovery Media
7.When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
8.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Please take time to rate me
Bud
Oct 31, 2012 | Computers & Internet
acer aspire one zg5 no erecovery
Hi ultraview27...
How to reinstall the Operating system on your computer
Note: If your computer does not have an internal optical disc drive,you will have to have an external optical disc drive because it will be used in order to recover the Operating System using Acer Recovery Media.
Sep 27, 2011 | Acer Aspire One PC Notebook
recovery partition of acer aspire 5720Z
Hi w abdallah25...
Select models of Acer laptops have Microsoft Windows partition , they have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Sep 27, 2011 | Computers & Internet
I have just purchased a HP 2133 mini-note. On first installation, installation failed and now it just loops and wont do anything. How can I facilitate first installtion bearing in mind there are no disks or disk drives.
The majority of these PCs have a recovery partition on the internal hard drive, here is the instructions for using it.
Recovering information using Windows Recovery Environment (WinRE)
Windows Recovery Environment (WinRE) can perform a recovery from either an optional external hard
drive or from recovery discs.
CAUTION: Using Windows Recovery Environment (WinRE) will completely erase hard drive contents
and reformat the hard drive. All files you have created and any software installed on the computer will
be permanently removed. When reformatting is complete, the recovery process will restore the operating
system, as well as the drivers, software, and utilities from the backup used for recovery.
To initiate recovery using WinRE, follow these steps:
NOTE: This process will take several minutes.
2. Restart the computer, and then press f8 before the Windows operating system loads.
3. Select Repair your computer.
NOTE: The "Repair your computer" option is displayed only if the WinRE partition is intact. If the
option is not displayed, refer to “Recovering information using a Windows Vista operating system
DVD (purchased separately).”
4. Follow the on-screen instructions.
5. Click Next.
6. Select your user name, type your password (if applicable), and then click OK.
7. If you are using recovery discs, insert the last disc of the recovery disc backup set.
NOTE: Inserting the last disc of the backup set confirms the presence of a valid backup. If you
insert any other disc, the backup will not be recognized.
– or –
If you are using an optional external hard drive, connect it to the computer.
8. Click Windows Complete PC Restore.
9. Follow the on-screen instructions.
this is getting long , so ill will post more steps in comment.....
Nov 20, 2008 | HP Computers & Internet
1,331 people viewed this tip
Seeker5211
Seeker5211
