Tip & How-To about Miscellaneous
HP Pro Tablet 408 G1 service manual support
Restoring factory settings in Computer Setup
To return all settings in Computer Setup to the values that were set at the factory, follow these steps:
1. Start Computer Setup.
2. Select Main, and then select Apply Factory Defaults and Exit.
3. Follow the on-screen instructions.
4. To save your changes and exit, select the Save icon in the lower-right corner of the screen, and then
follow the on-screen instructions.
- or -
Select Main, select Save Changes and Exit, and then press enter.
Updating the BIOS
Updated versions of the BIOS may be available on the HP website.
Most BIOS updates on the HP website are packaged in compressed ?les called SoftPaqs.
Some download packages contain a ?le named Readme.txt, which contains information regarding installing
and troubleshooting the ?le.
Determining the BIOS version
To decide whether you need to update Computer Setup (BIOS), ?rst determine the BIOS version on your computer.
BIOS version information (also known as ROM date and System BIOS) can be accessed by pressing fn+esc (if
you are already in Windows) or by using Computer Setup.
2. Select Main, and then select System Information.
3. To exit Computer Setup without saving your changes, select the Exit icon in the lower-right corner of the
screen, and then follow the on-screen instructions.
- or -
Select Main, select Ignore Changes and Exit, and then press enter.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Miscellaneous Logo
how to rest an hp elitebook to factory settings?
Hello, I can give you instructions to reset your computer to factory settings. Please write down all passwords and IDs, save any pictures or word documents and anything else that you feel is important prior to the reset. Print out these instructions. Read the instructions carefully prior to carrying this out due to the computer booting up quickly you may miss a step. I recommend you do a dry run prior to completing the function.
NOTE: Restoring defaults will not change the hard drive mode.
1.Turn on or restart the computer, and then press ESC button when the message "Press the ESC key for Startup Menu" is displayed at the bottom of the screen.
2.Press F10 (this should be your computer setup)
3.Use a pointing device or the arrow keys to select File > Restore Defaults.
4.Follow the on-screen instructions.
5.To save your changes and exit, click the Save icon in the lower-left corner of the screen, and then follow the on-screen instructions.
- or -
Use the arrow keys to select File > Save Changes and Exit, and then press enter.
Your changes go into effect when the computer restarts.
NOTE:
Your password settings and security settings are not changed when you restore the factory
settings.
Since I don't know exactly what model you have these are general directions.
Good luck
Jun 12, 2014 | HP EliteBook 6930p Notebook PC
how to hard reset or format samsung SGH-A777 since my screen has gone white and i cant see anything :(
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the right soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (8)
  4. Highlight, using the navigation keys, any of the following:
    • All: Sound Profile, Display, Phone, Alarm and Bluetooth settings will be returned to default values
    • Sound Profile Settings: Only sound profile settings will be returned to default values
    • Display Settings: Only display settings will be returned to default values
    • Phone Settings: Only phone settings will be returned to default values
    • Alarms: Only alarm settings will be returned to default values
    • Bluetooth: Only Bluetooth settings will be returned to default values
  5. Press the a737%20center%20key%5b2%5d.jpg key to check the box(es) of the desired Reset Settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is "0000"
  8. Press the left soft key for OK
  9. If prompted, Enter the password again to confirm, using the keypad
  10. Press the left soft key for OK
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Jun 03, 2011 | Cell Phones
i have an sgh-a877, impression, and I can't find a reset button. Is there one on this phone?
  1. From the standby screen, press Menu
  2. Press Settings
  3. Press Reset Settings
  4. Press on any of the following to check their boxes:
    • All: Sound Profiles, Display & Light, Phone and Alarm settings will be returned to default values
    • Sound Profiles: Only sound profile settings will be returned to default values
    • Display and Light: Only display settings will be returned to default values
    • Phone: Only phone settings will be returned to default values
  5. Press Reset
  6. Enter the password default password is "0000", then press OK
  7. If prompted, Enter the password again to confirm then press OK
  8. Press Yes to Reset the handset's settings to the factory defaults
May 25, 2011 | Samsung Cell Phones
My Samsung Impression A877 is lock out...... I forgot my password....... And I want to reset it...... from the phone lock screen....? Can anyone help me please!!!!
  1. Pull out the battery, and then reinstall it. Power on the phone and you should be able to access your information.
The following procedure will allow you to perform a factory reset, which would require access to the Standby Screen, and Menu. If you are just trying to access your phone, reset the battery.
To reset the handset to the factory default settings, follow the steps below:
  2. Press Settings
  5. Press Reset
Mar 01, 2011 | Samsung SGH-A877 Impression Cell Phone
How do I undo a reformat on an HP? My HP was reformatted and I need to return it to the previous state. Already tried system restore, but prompt said there is no point to restore to. Is there a way to undo the formatting and return the computer to where it was earlier today without buying recovery software?
Troubleshooting
Accessing Computer Setup
The information and settings in Computer Setup are accessed
from the File, Security, Tools, and Advanced menus.
1. Open Computer Setup by turning on or restarting the
computer. Press f10 while the F10 = Based Setup message is
displayed in the lower-left corner of the screen.
To change the language, press f2.
To view navigation information, press f1.
To return to the Computer Setup menu, press esc.
2. Select the File, Security, Tools, or Advanced menu.
3. To exit Computer Setup, choose one of the following:
To exit without saving any changes, use the arrow keys to
select File > Ignore changes and exit, and then follow
the instructions on the screen.
To exit and save all the settings you have entered, use the
arrow keys to select File > Save changes and exit, and
then follow the instructions on the screen.
Your preferences are set when you exit Computer Setup and take
Computer Setup Defaults
set at the factory:
2. Use the arrow keys to select File > Restore defaults.
3. Select the Restore Defaults check box.
2–2
Maintenance and Service Guide
Troubleshooting
4. To confirm the restoration, press f10.
5. Select File > Save changes and exit, and then follow the
When the computer restarts, the factory settings are restored, and
any identification information you have entered is saved.
Selecting from the File Menu
Table 2-1
File Menu
Select
To Do This
System Information ¦
View identification information about the
computer and any battery packs in the system.
View specification information about the
processor, memory and cache size, video
revision, keyboard controller version, and
system ROM.
Save to floppy Save system configuration settings to a diskette.
Restore to floppy Restore system configuration settings from a
diskette.
Restore defaults Replace configuration settings in Computer Setup
with factory default settings. (Identification
information is retained.)
Ignore changes and exit Cancel changes entered during the current
session. Then exit and restart the computer.
Save changes and exit Save changes entered during the current session.
Then exit and restart the computer. The changes
you save are in effect when the computer restarts.
2–3
Troubleshooting
Selecting from the Security Menu
Table 2-2
Security Menu
Select To Do This
Administrator password Enter, change, or delete an HP Administrator
password.
Power-on password Enter, change, or delete a power-on password.
Password options ¦
Enable/Disable stringent security.
Enable/Disable required password on restart.
DriveLock passwords Enable/disable DriveLock; change a DriveLock
user or master password.
DriveLock Settings are accessible only
when you enter Computer Setup by turning
on (not restarting) the computer.
Smart Card Security Enable/disable power-on support for smart cards.
This feature is supported by select smart
card readers only.
Embedded Security ¦
Enable/Disable the embedded security chip.
Restore embedded security chip to factory
settings.
Enable/Disable power-on authentication
support.
Enable/Disable automatic DriveLock.
Reset power-on authentication credential.
Embedded Security settings are accessible
only if the computer is equipped with an
Device security Enable/Disable devices in the system.
Enable NIC for inclusion in MultiBoot.
System IDs Enter user-defined identification values.
2–4 Maintenance and Service Guide
Troubleshooting
Selecting from the Tools Menu
Table 2-3
Tools Menu
Select To Do This
HDD Self Test options Run a quick or comprehensive self-test on any
hard drive in the system.
Battery Information View information about any battery packs in the
computer.
Jan 01, 2010 | HP Pavilion dv4000 Notebook
208 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
