Tip & How-To about Miscellaneous
HOW TO STRIP WIRE FROM HO/OO GAUGE LAMPS
  • HI I FOUND THAT THE BEST WAY TO STRIP WIRE FROM 00/HO MODEL LAMPS IS JUST TO USE A LITER AND BURN THE END THAT WAY YOU DO NOT NEED WIRE CUTERS
Miscellaneous Logo
headlamps inoperative daytime running lamps come on then go out jumped out headlamp switch ground circuit out still no headlamps.
It sounds like your DRL RELAY/Headlight relay. I had this happen with a 2000.
Please rate me if this helps You.
Here is some info that I hope is helpful to you.
This first part is how to disable the DRL
TOYOTA. From the Toyota technical service bulletin EL011-00 Web site for specific models determine where the module is; either the DRL relay or the body ECU, connector number, pin #. Oct 6,2000.
Avalon 1999 DRL relay D4 pin 1
Avalon 2000 body ECU B5 pin 6
Camry S/D 99* DRL relay D6 pin 23
Camry S/D 00* DRL relay D6 pin 10 *twilight sentinel
Camry Solara99/00* DRL relay D6 pin 23
Celica 2000* body ECU B6 pin 17
Corolla 99/00* DRL relay D3 pin 23
ECHO 2000 DRL relay D2 pin 12
4Runner 2000 DRL relay D8 pin 2
Land Cruiser 99/00 DRL relay D8 pin 2
MR2 Spyder 2000 DRL relay D2 pin 12
RAV4 99/00 DRL relay D17 pin 2
Sierra 99/00 DRL relay D4 pin 2
Tacoma 2000 DRL relay D8 pin 2
Tundra 2000 DRL relay D7 pin 2
-disconnect battery- Then remove the wire with pin attached and tape to the harness. (consider just cut and tape the wire) -check operation- [except the 2000 MY-Avalon, additionally you need to ground the wire at the module end of the cut wire]
And here is the Headlamp relay part number.
1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif ACDELCO 1pixel.gif 1pixel.gif E1717C 1pixel.gif 1pixel.gif [RELAY-HEADLAMP] RELAY,HDLP OEM#89057700 ALL MAKES
Mar 19, 2010 | 1998 Toyota Corolla
how to see the lyrics along wid hearing the song in transcend 840
U need to get the LRC lyrics file for the same.
This is nothing but lyrics after the time whne it starts.Save this with the same name as the mp3 file, in the same folder. and enable the lyrics sync.
For eg: For the song Jai Ho from movie Slumdog Millionaire: Copy paste:
[ar:Slumdog Millionaire]
[ti:Jai Ho]
[al:Slumdog Millionaire]
[00:16.13]Jai Ho Jai Ho
[00:22.64]Jai Ho Jai Ho
[00:27.45]
[00:29.83]Aaja Aaja Jind Shamiyane Ke Tale
[00:33.77]Aaja Jariwale Nile Aasman Ke Tale
[00:36.77]Jai Ho Jai Ho
[00:44.08]Aaja Aaja Jind Shamiyane Ke Tale
[00:47.58]Aaja Jariwale Nile Aasman Ke Tale
[00:50.64]Jai Ho Jai Ho
[00:56.02]
[00:58.58]Jai Ho
[01:00.83]Jai Ho
[01:04.52]Jai Ho
[01:07.52]Jai Ho
[01:12.33]Ratti Ratti Sachi Maine Jaan Gavayi Hai
[01:15.45]Nach Nach Koylo Pe Raat Bitayi Hai
[01:18.97]Akhiyon Ki Neend Maine Phoonko Se Uda Di
[01:22.52]Neele Tare Se Maine Ungli Jalayi Hai
[01:26.02]
[01:26.34]Aaja Aaja Jind Shamiyane Ke Tale
[01:32.34]Aaja Jariwale Nile Aasman Ke Tale
[01:36.66]Jai Ho Jai Ho
[01:39.78]Jai Ho Jai Ho
[01:45.84]
[01:49.90]
[02:08.15]Jai Ho Jai Ho
[02:13.34]
[02:14.53]Jai Ho Jai Ho
[02:22.33]Chakh Le Ho Chakh Le Ye Raat Shahad Hai Chakh Le
[02:29.52]Rakh Le Haan Dil Hai Dil Aakhri Had Hai Rakh Le
[02:38.90]Kala Kala Kajal Tera
[02:42.17]Koi Kala Jadoo Hai Na
[02:47.79]
[02:49.41]Kala Kala Kajal Tera
[02:52.59]Koi Kala Jadoo Hai Na
[02:55.96]Aaja Aaja Jind Shamiyane Ke Tale
[03:04.23]Aaja Jariwale Nile Aasman Ke Tale,
[03:05.92]Jai Ho,
[03:06.61]Jai Ho
[03:10.24]
[03:14.99]
[03:18.49]Jai Ho Jai Ho
[03:24.99]
[03:25.49]Jai Ho Jai Ho
[03:32.48]Kab Se Ha Kab Se Tu Lab Pe Ruki Hai Keh De
[03:40.93]Keh De Ha Keh De Ab Aankh Jhuki Hai.. Keh De
[03:49.07]Aisi Aisi Roshan Aankhe Roshan Dono Bhi Hai Hai Kya
[03:55.24]Aaja Aaja Jind Shamiyane Ke Tale
[03:58.80]Aaja Jariwale Nile Aasman Ke Tale
[04:02.74]Jai Ho Jai Ho
[04:06.62]Jai Ho Jai Ho
Apr 20, 2009 | Transcend T-Sonic 840 MP3 Player
box down new codes please telewest
New Codes:
Telepest 17th december
00 - C0 F6 61 87 91 F9 67 57
01 - E8 C9 E5 6E B0 49 53 F5
Dec 17, 2008 | StarTech.com StarView SV211K 2-port KVM...
109 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
