Tip & How-To about Office Equipment & Supplies
Brother MFC-J6910DW Review Printer
The professional series MFC-J6910dw will help your company develop with the versatility of duplex printing, copying and also scanning. Make two-sided documents approximately 11 inches x 17 inches house. Easy to arrangement wireless (802.11 b/g/n) or Ethernet network cable televisions with embedded assistance web link to others on the network. 3.3-inch touch screen different colors LCD display menu navigation attributes are interactive and easy to use. Dual paper trays (up to 250 sheets each) supplies an overall capability of 500 sheets. Utilizing Super High Yield (XXL collection) replacement ink cartridge around 2400 web page black and also colour 1200 pages. Neglected tight Fax, copy or scan with up to 35 web page ADF. 3 year minimal guarantee gives peace of mind.
Brother MFC-J6910DW Along with way over the typical paper handling, MFC-J6910DW offers all the standard features of any type of Office supplies, and much more. For a beginning, can print, check, and also Fax over a network and work as a standalone copier, facsimile machine, and also email of the sender. It can likewise check in tabloid dimension, utilizing the automated paper feeder web page 35 (ADF) or flatbed.
Duplex scanning lets you Fax records conveniently duplex, duplex printing as well as mixes while duplex scan additionally allows you duplicate both Simplex (one-sided) as well as duplex record to your liked copy simplex or duplex. Keep in mind, nevertheless, that duplexing for scanning is restricted to an optimal legal size web pages, although the ADF can take care of tabloid dimension web pages to scan Simplex.
The common setup. The printer offers Ethernet and WiFi assistance. For the tests I attached to a wired network and installed it on a Windows View system. Not incredibly, offered the similarity between the printer, MFC-J6910DW the outcomes are basically the very same, documents by file, the MFC-J6710DW, as well as the Bro MFC-J6510DW ($ 250, 4 stars), basically the budget variation of the very same ink-jet printer, with just one paper tray.
I clocked up all 3 printers on our business applications suite (making use of QualityLogic's hardware and software for the time) in 4.1 reliable pages per min (ppm), making them is bound to be a tabloid-capable inkjet asserts the fastest we've checked to this day.
Brother MFC-J6910DW
Amongst the single-function inkjets, editor options Canon Pixma iX7000 Inkjet business Ink-jet printer ($ 399.99 straight, 4 stars) are primarily slower, ppm 1.7. And also between inkjet MFP, HP Officejet options editor formerly 7500A Wide Layout e-all-in-one ($ 299.99 direct, 4 celebrities), can be found in at 3.4 ppm.
The quality of output and also other troubles
Generally, the top quality of the outcome of the MFC-J6910DW equal to or far better than many inkjets across the Board, and also the lid fits MFC-J6710DW MFC-and J6510DW. This text agrees with for a lot of company applications, as long as you do not have an uncommon demand for small fonts, as well as the photo output on picture paper are roughly matched to prints of **** stores, making it greater than adequate for a lot of business requirements.
Different colors in the graphics are slightly dulled down yet also within affordable variety. Right here once again, the quality is conveniently adequate for a lot of business needs, including, as an example, PowerPoint handouts. I see some allure in the default mode, yet it relies on how much of a perfectionist, you can take into consideration a sufficient graphics for outcome will certainly be essential clients or clients.
Dued to the fact that the MFC-J6910DW provides every one of the very same capacities that make MFC J6710DW-editor choices, including the capability to copy, fax, print as well as scan in tabloid dimension, and also print in duplex, extremely easy to suggest. Certainly, if you ever before have to scan a two-sided paper, you're far better off conserving a couple of bucks and purchase a MFC-J6710DW instead. Yet if the duplex Scanning is something that you need or believe you could need, Brother MFC-J6910DW is the apparent option, and also it is still cheap.
All in One Multi Function Brother MFC-J6910DW
I lost my disk and purchased a new lap top please help
All Products ' Printers & MultiFunction ' Lexmark Platinum ...
www.lexmark.com/platinum
LexmarkPrint. Copy. Scan. Fax. The wireless Lexmark Platinum Pro905 all-in-one with fastprint speeds, individual ink cartridges and photo features delivers versatile ...
Lexmark Support & Downloads for Lexmark Platinum Pro905
support.lexmark.com > ... > Product Selection
LexmarkLexPrint Photo Printing App Withdrawn (December 2012). Lexmark's Mobile Printing... Please Select your Operating System (Why can't I find my printer driver?) ...Missing: w ‎duplex
Dec 26, 2015 | Lexmark Platinum Pro905 Wireless...
how to scan to an external hard drive from brother printer
Can't get the Brother MFC-240C printer to print. I have everything connected.
Oct 29, 2012 | Brother MFC J6910DW - Multifunction fax /...
mfc j691dw unable to init AF what does it mean
I cant get rid of 'unable to init.42' from my new mfc j6910dw. Anybody know what does it mean & how to remove the mssge?
Oct 14, 2012 | Brother Mfc-j6910dw Inkjet Multifunction...
double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Does printer need to be connected to a pc?
From the Brother website: The MFC-5440cn offers both a versatile flatbed and an automatic document feeder with faxing and copying that don’t require the use of a computer. Add to that the spectacular high-resolution printing and scanning with both a USB 2.0 full speed and an Ethernet interface and you have the perfect all-in-one for the Small Office/Home Office user to create and print professional color documents. You can even print borderless photos.
Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | Brother MFC-5440CN All-In-One InkJet...
835 people viewed this tip
k24674
jasbo
jasbo
