Tip & How-To about NU -set Gsm Padlock Alarm System - Portable Security
GSM alarm system with RFID & APP control and Touch keypad
NU -set Gsm Padlock Alarm System - Portable Security Logo
I just replaced the control board and now it won't reset
Hi try this. 1 press & hold the door alarm keypad. .2 press & hold freezer temperature down keyboard within 3 seconds. .3 release the door alarm alarm keypad and wait 3 seconds. 4.the control will DISPLAY PE to indicate the programming mode 5.entry is confirmed by pressing the freezer temperature down keypad once more. .6 the control will display the current program CODE this program should be validated with the program CODE printed on the unit serieal plate ..NOTE.IF THE PROGRAM code is correct the programming mode is excited by pressing door alarm keypad for 3 seconds. .7.press the refrigerator temperature up keypad or refrigerator down keypad to change the digit value with each key press. 8,. the decimal point indicates the selected digit press the freezer temperature Up keypad to select next digit. . 9.. Once the desired program code is entered press & hold the freezer temperature down keypad until the program CODE begins flashing indicating it has been saved.Note.if u attempt to enter an invalid code the control will not save the new code ...but will beep ,,(the unit will not run with a program code of 0000 ,). Once the program CODE has been saved the programming mode is excited by pressing any key.if the new code is incorrect this process should be repeated.the programming mode can be excited at any time by pressing door alarm key for 3 seconds or will exit if unattended for 4 minutes..good luck
Jun 16, 2016 | Maytag Refrigerators
Can I program my Vista 20p to call me instead of a monitoring station? I have a GSMX4G also installed and I purchased, activated and installed a AlarmSim 2.0 card
I don't know anything about the GSM system you've mentioned, but if it connects to the phone terminals then the system can probably be programmed to page you rather than calling an alarm company. There is an entire section in the program guide for alarm paging. However, be advised that you're rolling the dice with security if it's your intention to monitor the system yourself...if the security of your home is important to you I recommend that you have it monitored by a UL certified monitoring center.
Jun 12, 2015 | Honeywell Vista 20P Alarm System Kit with...
Audible alarm sounded--"F2 "appeared on
Your model is actually a 911. Roper (Whirlpool)
The F2 error code is
E0 - Shorted keypad (also called touch pad)
E1 - Keypad cable unplugged
E5 - Cancel key drive line open
E6 - Cancel key drive line open
Solutions:
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 30, 2011 | Ovens
I want to have a centralized rfid reader connected to my pc to be able to detect rfid tags. I want to develop a system that will use such technology to track assets. Which rfid reader model would you advise me to go for?
rf ideas, air id playback- rfid reader contactless usb external model found here http://www.google.com/products/catalog?q=usb+rfid+reader&oe=utf-8&client=firefox-a&cid=9940774338525004821&os=sellers# it is what i use to track inventory in the store i work at please let me know if that helps
i love this product by the way good range! and easy to move around. if this works for you im glad would love a comment testimonal if it does lol
Mar 15, 2011 | Computers & Internet
system keeps beebing all overthe house - how do you stop it -help please
The resolution depends on the code being shown on the keypad. The first two things that come to mind are 1> The control panel's backup battery is low and not accepting a change and needs replaced, or 2> If the code on the keypad shows 'BF', this is Backup Failure, and it means that your backup communications device, such as a GSM Long Range Radio, is not functioning. If you see this code on the keypad, immediately call your local alarm company for a fix. If your communications are down, police / fire / ems will not be dispatched in the event of an alarm.
Mar 04, 2011 | Ademco Home Security
212 people viewed this tip
Top NU Home Security Experts
Lawrence Oravetz
Are you a NU Home Security Expert? Answer questions, earn points and help others
