Tip & How-To about Garden
MTD Yard Machine 22 inch 179cc Transmission removal and installation
I had the transmission on my MTD yard machine fail. I removed it and replaced it with the updated version. I then tested it and once confirmed it was repair I then decided to break open the transmission and discovered why it failed. You have go to see this......
MTD Yard Machine 22 inch 179cc snow blower transmission repair
Garden Logo
I have a model 600-699 1998 MTD 46in YARD MACHINE. Is it possible to check/add fluid to the trans axle?
I had a 1999 yard machine that did the same thing i had to replace the transmission it was still working when i sold it this year
Sep 04, 2017 | Mtd Garden
mtd yard machine mod#42A707 flywheel
Your probably will looking an used replacement on Ebay. Also you should use the complete engine info to look-up the correct flywheel but is the most common flywheel. Covers about 150 versions of the 42A707 series.
Flywheel 691976 for Briggs and Stratton Lawn Equipment eReplacement Parts
Feb 11, 2015 | Mtd Garden
how do i replace pull cord on mtd 31cc tiller
Remove your recoil housing. Turn the inside to see if spring is broken. If spring is good wind it up as tight as it will go without forcing it. Once you have it wound all the way then back it off one turn or until the eyelet meets where the rope comes out. tie a knot in one end and feed through both holes. Pull the rope through till the knot is tight then attatch your handle. Once the handle is in place slowly let the rope wind itself in. pull a few times to make sure your knot is holding and reinstall on engine
Jul 16, 2014 | Yard Machines Mtd Yard & Garden Cultivator...
Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Apr 22, 2009 | Mtd 22" Yard Machine Push Mower
Can't keep mower running without consistently pushing the primer.
It sounds like there is water in the gas. The only way to remedy this is to take the carb off of the gas tank and replace the diaphragm, there is a small reservoir between the tank and carb...clean with WD-40 to remove water
Apr 05, 2009 | Mtd 22" Yard Machine Push Mower
552 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
