Tip & How-To about Microsoft Wireless Keyboard 2000
Disassemble a Microsoft Wireless 2000
To disassemble the keyboard, remove the battery cover and batteries. There are a total of 20 screws holding the keyboard together; 10 visible screws, the rest are hidden. Six are under the very top row of keys (Home key, 5 numbers, zoom, play, etc.). With the keyboard right side up, carefully place a thin, flat blade under one side of the edge between the keyboard and top key panel. Work the flat edge along the keys, gently prying them up. It is one piece. Once it's off, you will see the screws under small paper covers. Save the covers. Turn the keyboard over to view the bottom, wrist pad nearest you, labels upside down. Two of the screws are under the right side of each label. The other two are hidden under the rubber feet on either side of the battery port opposite the wrist pad. I recommend placing all the screws to one side in rows as they come off because some are shorter than others.
Microsoft Wireless Keyboard 2000 Logo
computer was locked
Resetting the CMOS password on an Acer Aspire laptop is much more difficult than resetting the password on a desktop.
Disassembly steps vary from model to model, but on most models, you'll have to take apart the computer to access the CMOS battery.
Don't take apart the notebook if you don't have experience disassembling PCs.
After turning off the computer and disconnecting the AC adapter, take out the battery (different from the CMOS battery).
All visible screws must then be removed from the bottom of the notebook.
Remove all components stored to their separate compartments on the base of the notebook.
Turn over and open the PC. Lift up the switch cover and remove the screws securing the keyboard to the PC, if any are visible.
Remove the keyboard.
Remove the screws securing the monitor to the hinges, and then set the monitor aside.
Disconnect all visible cables connected to the motherboard; and then remove the screws from the top cover.
Remove the top cover to reveal the motherboard. Locate and then remove the CMOS battery. Leave it out of the notebook for 24 hours; then reinstall it and reassemble the Acer Aspire.
Other Options
If removing the CMOS battery fails to clear the password, or if you dont feel comfortable with the idea of opening your computer, you might be able to gain access to the computer using a backdoor password.
These special passwords were implemented to allow technicians to access locked computers. Not all models recognize backdoor passwords.
Most Acer Aspires use the Phoenix BIOS, and backdoor passwords for this BIOS include BIOS, CMOS, phoenix and PHOENIX.
All of these passwords are case-sensitive.
Apr 22, 2013 | Acer Computers & Internet
how to unlock a computer
Is it an aspire ?
Other Options
where is the cmos battery located in the computer??????????
#1
Turn off the laptop and remove the AC adapter. Remove the battery from its compartment on the bottom of the computer. Turn the laptop over and remove the screws holding the DVD drive in place and pull out the DVD drive.
#2
Remove the remaining screws on the bottom of the computer. These screws secure the wireless card cover, the memory card cover and the modem card cover. Then remove all of the plastic covers. Remove the wireless card by sliding it gently out.
#3
Remove the corner screws on the bottom of the laptop securing the bottom housing. Remove the housing by pulling it away from the laptop. Remove any remaining, exposed screws on the bottom of the computer.
#4
Turn the laptop over and remove the thin plastic strip that runs along the border of the keyboard with your fingernails. If your fingernails aren't long enough, a plastic card will work as well.
#5
Remove the two screws on either side of the keyboard securing it to the computer. Remove the keyboard.
#6
Remove all of the exposed screws where the keyboard used to sit. These screws secure the top housing to the computer. Remove the housing, exposing the motherboard.
#7
Locate the CMOS battery. It is a small battery about the size and shape of a coin and should be easily visible on the board. Depending on the model of Toshiba you are working on, the CMOS battery will either be secured with a clip or connected to the board by two small cables. Either way, they are easily removable.
#8
Disconnect the battery by pulling gently away from the cables or by popping the clip out. Your CMOS battery can now be removed
Oct 06, 2010 | Toshiba Satellite X205-SLI1 Notebook
trouble seperating top cover from base/mobo / asus f3s notebook
Have you removed the keyboard, sometimes there is a screw under the keyboard that holds the top and bottom of the case together.
Most laptops have clips/indents that clips top and bottom half of the case together. Start on one side, preferrably at an opening where the CD/DVD drive is located and gently apply pressure to separate the case along that edge. Once you free a catch/clip start working along that edge and continuing around to each side of the case.
Mar 26, 2009 | ASUS F3SC-B1 Notebook
I would like to disassemble Motorola Z9 phone. Any ideas how to do it?
  1. Turn the phone off
  2. Push the battery cover up, towards the top of the phone to release it
  3. lift up and remove the battery cover
  4. Pull the tab on the label near the hinge, then remove the battery from the
    phone.
  5. Remove the sim card and the sd card
  7. Using a Torx driver with a T-5 bit, remove the screws at each side of the phone.
    Retain the screws for reassembly.
  8. Turn the phone over so the keypad is facing upward.
  9. Use the disassembly tool to remove the bumper pad below the keypad
  10. 7553166.jpgThen remove the two screws under.
  11. turn the phone over so you see the back Release the first housing latch by inserting the flat edge of the plastic
    disassembly tool at an angle through the slot on the rear housing then push
  12. The rest of the service manual is available at
  13. http://www.4shared.com/file/67373684/bf0a868f/Service_Manual_RAZR_V9.html
Feb 18, 2009 | Motorola Mobility Z9 Cellular Phone
933 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
