Tip & How-To about Saws
Jig saws that won.t stay on
The jig saw might have a short some where because when you tap it ,it comes on every time, that sounds like a short to me, have it looked at. by john zehr
Saws Logo
how to use a Stanley 92870dovetail jig
Sir,
There is an interesting man I believe can stimulate your enthusiasm to be a success. Please? Take the time to travel to this link and watch this short but novel approach to building drawers.
Frank Klausz Dovetail Drawer DVD intro
As far as your saw. I would build a base jig to match the depth and width of your work piece, follow your layout leaving half the line. look over Kluasz' library and your sure to be as wide eyed and smiling as you will when your projects come together.
I have always advocated. New wood smells good. Fare . Well.
Apr 26, 2014 | Saws
jig saw b4300 blade replacement
This tool has no mechanism for the fixating ot the saw but only a short ***** part 53 its a fault in the manual , it simply replace the saw with a screwdriver. or simply the clamp ***** to release turn it loose and from the top you can replace the clamp *****
Bosch B4300 0601582535 Jig Saw Parts
Sep 05, 2013 | Bosch 1581AVSK Top Handle Jig Saw Kit
Model 1581VS Bosch jig saw, Cannot get blade changing screw out
from what I remember you should be able to just unscrew it and it comes out the top end of the spindle. when you get it loosened you might have to "TAP" on the side to get it out. There might be some debris or a burr on the threads making it difficult. Go to "ereplacementparts.com" and you can look at a breakdown for this tool and the screw is position #53. The part number is 2603400000.
Apr 23, 2011 | Bosch Saws
Switch capacitor short circuit. Makita jigsaw
This capacitor is only used for RF suppression... really IF it is shorted, then simply remove it. It should work fine without. just be noisy around radios etc. But if you want to replace it Radio Shack, or Radio Spares, should have one.
Feb 14, 2010 | Makita 4329k Top Handle Jig Saw Power Tool...
Blade comes out while sawing
I have used the same tool. Make sure that the blade release/ hold tab is engaged. Maybe the return spring is fouled or stuck. Try some lubricant.
Jun 20, 2009 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
232 people viewed this tip
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
