Tip & How-To about Bh Fitness TS4 Treadmill
Treadmill Troubleshooting
Belt Adjusting
When the running belt shifts to one side or simply 'skids over' while running, run the machine at 3 mph for a few minutes to determine which side the belt is drifting towards, left or right as described below.
If the belt is drifting LEFT
# Turn the treadmill off and unplug from the wall
# Tighten the left hex head socket a ¼ turn
# Loosen the right hex head socket a ¼ turn
# Run the belt at 3 mph again for a few minutes
# Repeat the steps above as needed
for error codes and more check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Bh Fitness TS4 Treadmill Logo
belt shifted to side
You need to tension the belt .
Turn the machine on and up to 4 kph or 3 mph.
Stand on the side rail with 1 foot and try and stop the belt with the other. If you can stop at all tighten the rear roller with the allen key provide with the machine. Turn it on both sides clockwise 180 deg whilst machine is still running. If still loose tighten another 90 deg.
Jan 27, 2013 | HEALTHRIDER R60 SoftStrider Treadmill
I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA Managua, Nicaragua. C.A.
Sep 26, 2011 | Precor C954i Commercial Treadmill
I have noticed a few times that my f3 life fitness treadmill changes pace on me, and so does the incline. i can see it on the monitor, also it has started feeling like the belt is catching or something, or suddenly sticking for a second mid run? Should i call out to have it serviced..... again? I have only had the treadmill for a few months and have had several problems- next time i drop 3k on equipment it won't be with life fitness!
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
Jul 18, 2010 | Life Fitness F3 Folding Treadmill with...
Belt is slipping,
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill running belt adjustments.
Jul 06, 2010 | Life Fitness 9000 Next Generation...
217 people viewed this tip
Top Bh Fitness Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Electro Med Services...
Tom Chichester
Are you a Bh Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
