Tip & How-To about Apple iPhone 3G
Tips
Screen Shot
Hold the Home button, then hit the "Power/Sleep" button, the screen will momentarily flash, and the iPhone's current screen contents will be saved to the Camera Roll.
Scrolling up
Simply touch the "Status Bar" at the very top of the screen (this is where the time is). When you're in MobileSafari and the Mail application you will automatically scroll back up to the top of the page (or email).
Auto TLD
You have to have Google set as the default search engine for this to work. After this is set, you can just put "apple" into the browser, and press "Go". It'll automatically take you to the Apple website.
Set content restriction
General -> Restrictions" then tap Enable Restrictions and enter a four-digit passcode to restrict your content.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apple iPhone 3G Logo
my ipod comes up with a message that says " ipod is disabled " ... ive tried to reset it .. but i dont have the original computer ... i went to apple and requested my passcode ... it sent me the excact passcode i put on it and it still wont unlock ... what do i do ..?
It happened with my iPod too and my cousin brother helped me fix it. He tried the below steps:
Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
# Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
* If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on.
Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button.
If necessary, open iTunes. You should see the following "recovery mode" alert
Hope that resolves the issue. Please revert for any further issue.
Regards
Anand
Apr 27, 2011 | Apple iPod touch
i reset my iphone 3g and now its been frozen for 2 days, it only shows start-up apple logo. please help!
Do a hard reset.
  1. Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
  2. Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart.
  3. You may let go when you see the silver Apple logo.
  4. You have completed a hard reset successfully.
  5. Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen. This is normal.
If this does not work, put into recovery mode and restore from itunes.
Step One
Open iTunes and connect the iPhone to your Mac.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
As soon as the screen goes black release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone will look like this:
Feb 28, 2011 | Apple iPhone 3G
I opened my settings option and was fooling around with the passcode option when I set my phone down to answer the door. The last thing I remember my phone saying was "new passcode" so I think it went to a default passcode. What should I do about this?
Plug it into iTunes with it at the unlock screen. Somewhere it should say "Unlock your iPhone" or something like that in iTunes. Click it. Otherwise do a restore by going to the screen where it shows how much memory you have used up in iTunes and click
or:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Dec 03, 2010 | Apple iPhone 3G
I am getting a "No SIM card Installed" message -
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Nov 30, 2010 | Apple iPhone Smartphone
my iphone froze i took a screen shot and the screen is completely white im still getting calls and text messages but i cant acess them i need help now!
Trying doing a hard reset on your iPhone:
1. Press the home button (the big circle below the screen) and the sleep wake button (the button on top of the iPhone) simultaneously.
2. Hold both buttons simultaneously for a few seconds, Ignore the "Slide to power off" and keep holding
3. The iPhone should now shutdown automatically - (fade to black)
4. Turn the iPhone back on by hitting the sleep/wake button.
5. You should now see the Apple logo, your iPhone is restarting and thus booting up.
6. You have completed a hard reset successfully.
Oct 20, 2009 | Apple iPhone 3G
766 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
