Tip & How-To about Video Game Consoles & Games
How to fix an xbox 360 when tray dont open
Pull on it gently and then pull it hard
Video Game Consoles & Games Logo
when my i-pod is attached to my computer it works and when it is
You need a new battery then. You can order one online for a reasonable price and installation is fairly easy. I have posted two web sites that sell batteries for iPods as well as step by step instructions for the click wheel iPod models. www.ifixit.com
iPodbatterydepot.com
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
With the casing separated, grasp the top half (the part with the front bezel) and flip it over. Note that there is an orange cable in the top left corner that connects the iPodlogic board to the headphone ports. If you gently grasp the cable and pull, it will slide out of its connector on the headphone port module board.
Headphone Jack Board Removal Before proceeding, you must remove the top case.There are two t6 screws holding the headphone port in place. Remove both of these screws. You can now remove the headphone module.
Hard Drive Removal Before proceeding, you must remove the top case.Hold the hard drive up, and remove the black tape on the hard drive connector. This will reveal the hard drive cable’s connector to the logic board.To remove the hard drive, grasp the cable (thumb on top index finger onbottom) and gently pull the cable out (away from you and the connector)The hard drive will now be free of the iPod logic board.
Hard Drive Cable Removal Before proceeding, remove the hard drive.To remove the hard drive cable, hold the drive, and gently pull up on the cable.It should come out easily.
Headphone Connector Cable Removal Before proceeding, remove the hard drive.To remove the headphone connector cable, Grasp the cable, and gently pull up. It should come out easily.
Logic Board Removal Before proceeding, remove the hard drive and headphone connector cable First, disconnect the battery connector by grasping the cable and gently pulling up to disconnect the cable from the logic board connector. Remove the 6 black T6 Screws.
With the screws removed slightly move the logic board to the left to give more access to the clickwheel cable. Gently pull this cable to free it from the logic boardconnector.The logic board will now easily come free from the case. The LCD will still be attachedto the logic board.
LCD Removal Before proceeding, first remove:Hard DriveHeadphone Connector CableLogic BoardTo remove the LCD, grasp the green connector cable, and gently pull to free it from the logic board connector. It should come out easily.
Battery Removal Before proceeding, first remove:Hard DriveHeadphone Connector Cable Logic Board To remove the battery, use a flat tool to pry the battery up. It is held on with a lightadhesive, and should come up by using just a little force. Lift the battery out of the unit.
Everything goes back in with gentle pressure and of course replacing screws and what not. All in all though, it is allot cheaper then buying a new iPod or other MP3 player :) I hope this is helpful to you
May 09, 2009 | Philips GoGear SA5285/37 Digital Media...
DEAD IPOD 8GB
You can disasemble the iPod to see if there is any visable water damage. If there is and you want to replace it, you can go to www.ifixit.com and order the appropriate parts there. Also at the bottom of this entry you will see another web address. This is where you can watch free iPod repair video's. :)
http://fixyouripod.weebly.com
Mar 21, 2009 | Apple iPod touch
ipod won't turn on
You may need a new hard drive for your iPod. Its allot easier to replace then you would think to :) If you go to the following web page there are a few video's on trouble shooting this kind of issue as well as instructions on taking apart the ipod and replacing a few of the items. Also below I have posted a step by step guide on completely disasembeling an iPod.
http://fixyouripod.weebly.com/
http://www.ifixit.com/
Mar 10, 2009 | Apple iPod nano
water damage
It sounds to me like you need a new battery for your iPod. To order a replacement battery kit, you can go to (www.ifixit.com) There is also a free video at (http://fixyouripod.weebly.com) Below is also a step by step instruction (guide) to taking apart the iPod piece by piece so that the replacement can be done in an easy safe manner. If for any reason you have difficulties please do let me know :)
Feb 27, 2009 | Apple iPod nano MP3 Player
IPOD 20GB CLASSIC
Jul 13, 2008 | Apple 20gb Ipod Mp3 Player With Click...
300 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
