Tip & How-To about Miscellaneous
How to find your engine.
First find the lift hood feature- it should be on the left undercarriage side of your drivers side.
Second - Pull it.
Third - Find the lever on the front of the car and then pull or push it sometimes they go left sometimes right.
Fourth- Open Hood and make sure you use the stick to prop the hood from crushing you.
Fifth- Open your eyes. Do you see that, that there is your engine.
Miscellaneous Logo
How do I open the hood?
On your driver side, lower left side, down to where you would place your left feet, there is a handle that has a hood logo on it, pull this handle back, and your hood should be released, then go to your hood, toward the center of the hood, slide your hands under the hood and lift it up a little bit, (it won't open yet) then there is a release lever that needs to be pull, (be easier if you take a look) with your fingers, and once you pull on it, should release your hood, and then open the hood.
Jan 26, 2011 | 2005 Mitsubishi Galant
where is cabin air filter location
Hi if you have the 3.8 then follow these instructions.
Hi
  1. Left sound insulator panel.
  2. HVAC air filter access cover.
  3. Pull first filter out using filter tab. Filters will bend to clear accelerator pedal.
  4. Pull the second filter out using tab.
  5. Pull the third filter out using tab.
Install or Connect
Important
  • When installing the filter care should be taken so that the filter does not become dislodged from the channel inside of the HVAC module.
  1. First filter in case. Use the tab and raise the filter parallel, so that the leading edge catches on the holding rib.
    • A long thin bladed screw driver may be useful in lifting the filter parallel to the HVAC module.
  1. Engage the second filter in the tab of the first filter and slide it into the remaining channels of the first filter.
  2. Use the tab and raise the filter parallel, so that the leading edge catches on the holding rib.
  3. Engage the third filter in the tab of the first filter and slide it into the remaining channels of the second filter.
  4. Fold the second filter tab down and the third filter tab up and over the second.
  5. HVAC air filter cover.
  6. Left sound insulator
Sep 17, 2010 | 1998 Buick Park Avenue
Unable to open hood of Volvo
I have a '95 and the lever is beside the drivers left leg. You pull this lever and then go out and lift up the hood about an inch. A second lever shows out the front grill. You pull this second lever to release the safety catch so you can open it the rest of the way.
Dec 29, 2009 | 1997 Volvo 850
how do you open 1999 escalade hood
When you sit in the drivers seat there is a lever on the left side panel by your left foot. Pull the lever and push it back in place. this releases the hood latch. then reach just under the hood and another lever is there that you can push up as you lift the hood.
Apr 04, 2009 | 1999 Cadillac Escalade
Release hood on 2003 c230 Mercedes
Pull the red lever under the drivers side dashboard-about where your left knee would be, sitting in the vehicle. The hood will pop up and a tongue will protrude through the front grille. Pull this tongue and at the same time, lift the hood.
Oct 05, 2008 | 2003 Mercedes-Benz C-Class
153 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
