Tip & How-To about Saws
Jig saw plates how to keep them from tipping.
Tighten the ***** to tighten the plate that sets on the wood tighten it as tight as you can with out striping the ***** it worked for me.
Saws Logo
Clutch&tranny help
you need first wipe clean fly wheel and pressure plate machined surface clean then you need to install position clutch disc and pressure plate with clutch held in place with alignment tool. tighten pressure plate to flywheel bolts only finger tight.working around pressure plate.center the clutch disc by ensuring the alignment tool is through the splined hub and into the recess in the crankshaft.wiggle tool up down or side to side as needed to bottom tool.tighten the pressure plate to flywheel bolts a little at a time working in a crisscross pattern to prevent distortion of the cover.after all bolts snug tight tighten then torque bolts 30 ft lbs for V8 if engine V6 torque bolts 15 ft lbs.be sure to use high temperature grease on release bearing inner groove place grease on transaxle input shaft bearing retainer.
Jun 16, 2013 | Cars & Trucks
The holder has fallen off the wall. There appears to be two screws, one that fits into the back of the centre of the wall plate and a small one that fits into the side of the wall plate. I don't think anything is missing but I can't get it to stay on the wall. Can you help me,please? Alicia
Hello Alicia
Most often the wall plate will screw to the wall and then there is a set screw (usually an allen key) to tighten the fixture onto the wall plate. If it is the wall plate that won't stay on the wall then your screw holes are probably stripped. An easy way to fix this is to fill the hole with a wood glue filler available at your local hardware store. Use toothpicks to jam the filler into the hole. You can also use white wood glue and jam glue and toothpicks into the hole. Let it dry overnight and the next day you will be able to screw the plate back onto the wall. If the fixture is falling off the wall plate then the set screw is not being tightened hard enough against the plate to hold it onto the wall. Good luck with the repair.
Jul 17, 2010 | Sonia GENOA COLLECTION TOILET ROLL HOLDER...
how do i put a chain on the chainsaw
Set out the chainsaw parts in front of you. Make sure the chain is facing the right way to cut wood; the teeth should be facing away from you when you are holding the chainsaw.
Secure the chain around the sprocket (a cog-type part found near the chain tension nipple) and align it along the grooves of the bar. You will see a hole for the chain-tension nipple on the end of the bar. Line these up so the nipple fits in the hole on the bar. Pull the chain to tighten it, using the screw to achieve the desired tension
Place the cover plate back on top of the bar and line up the cover-plate housing screws with their corresponding screw holes
Screw the cover-plate housing screws back in and tighten. Test the chain to make sure it spins freely when pulled.
Check the chain to make sure you can lift it about 1/4 inch, so it isn't too tight to spin while cutting wood
Dec 21, 2009 | Televison & Video
grohe ladylux faucet is loose
if you have an access panel behind it, take it off then wedge a peice of wood between the pipes and the wall, if you do not have an access panel take the cover plate off and wedge the wood thru this hole, do not over tighten just snug it you will be fine, remember to chaulk around the cover plate when done let set up for 24 hours
Jun 04, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
200 people viewed this tip
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
