Tip & How-To about Miscellaneous
WHAT TO DO IF IT STILL SHIFTS ROUGH AFTER CLUTCH INSTALL
I recently install a clutch on my 1999 gmc sonoma and after install it would shift but barley like something was wrong with my slave cylinder but how could this b i said the salve cylinder is a aluminum cast piece how can that mess up it doesn't install with a casket or nothing just 2 bolts but i reserved it had to b done but i procrastinated almost a year exactly till one day snap the pedal went to the floor and i was like wtf after careful inspection i found that a hinge pin on the side of the clutch pedal had indeed come all the way out so i went to my local pull apart and got one and after install which is a breeze my truck shifted flawlessly i was astounded this whole year of dread of having to take the tranny and the clutch back out all for not so check that if u have the same problem cause that was it and NOBODY FIGURED THAT OUT OF ALL THE MECHANICS I ASKED WHICH WAS VAST AND SO SO MANY
see the pedal wasn't putting enough pressure on the plunger so i was basically shifting with have a clutch depressed it was so rough to shift and i had to force it so much it eventually broke of my shift tower after i replaced that i was like mayb that was it the whole time WRONG it still shifted like do-do till the pedal finally broke all the way off ROFL OH WELL U LIVE AND LEARN even after 45 years of living
PEACE AND LOVE TO ALL WHO 420
Miscellaneous Logo
I have a 1999 gmc sonoma which I recently had clutch replaced however it still won't go into gear. Any suggestions as to what else it cold be?
did you have it pro replaced? If so, you should take it back to them. How long is your warranty? If you personally replaced, you need to check the service manual. Here is the owner manual
1999 GMC Sonoma TSBs CarComplaints com
and you may find this info about clutch issues here
How to Adjust the Clutch on 1997 GMC Sonoma eHow
Jan 10, 2015 | 1999 GMC Sonoma
gmc sonoma clutch
my clutch problem was the cluch pedal the gromet holding clutch piston the pedal was worn an could not shift I replaced the part auto zone or one of those place carry it as an after market part...not sure if this will help
Apr 01, 2014 | 1998 GMC Sonoma
how to replace a clutch and a slave cylinder
I recommend you get the Haynes repair manual on your vehicle. That will explain how to do it correctly.
Jul 12, 2010 | 1996 GMC Sonoma
cluth line to transmission is leaking and loose on transmission
slave cylinder, first check to see if it has fluid, than bleed like you the brakes, there is a resvoier for just the clutch it is usually held on w/ 2 bolts the slave cylinder
Sep 19, 2009 | 1991 GMC Sonoma
gears grinding when trying to shift in a gmc 3500.
some aftermarket masters don't push enough fluid to the slave to disengage the clutch even from the same maker
Sep 04, 2009 | 1985 GMC K3500
84 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
Philippe Dekyvere
Level 1 Expert
bill tarkulich
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
