Tip & How-To about Vehicle Parts & Accessories
When asking for automotive help.
Please mention the YEAR, MAKE, MODEL and the ENGINE size when asking for any kind of automotive help. Thanks.
Vehicle Parts & Accessories Logo
how much to fix a P0446
Year, Make, Model, and Engine Size? Depending on the year a P0446 usually indicates a problem with a VSV on the charcoal canister. In which case the canister gets replaced. Please post a Year, Make, Model, and Engine Size every time you have an automotive question. It will make it easier to get you the info you need!
Aug 11, 2012 | Toyota Camry Cars & Trucks
fuel pump wont shut off
To begin with, it is absolutely impossible to look up anything like wiring diagrams to see how your fuel pump sysem works because you failed to mention what kind of vehicle you are working on. YEAR, MAKE, MODEL, and ENGINE SIZE is customary when you are asking for help with an engine or engine fueling problem.
With that said, your symptom description mentioned "handle bar". There are no cars or trucks that I am aware of that are equipped with handle bars....I think you will probably get a more useful answer if you were to include the information needed to look up technical information and post it under the correct category.
May 22, 2012 | Cars & Trucks
rear ended car died and now it wont start
The collision most likely tripped the inertia switch for the fuel pump. It can be reset by simply pushing the button. However, I cannot tell you where it is located because you did not take the time to mention what kind of car got rear ended. YEAR, MAKE, MODEL, and ENGINE SIZE would be nice when you are asking questions about your car.
Apr 14, 2012 | Mercury Topaz Cars & Trucks
removal front struts
Take the upper strut mounts loose, take the lower strut mounts loose. Depending on what kind of vehicle we are talking about, you may need to disconnect a lower ball joint, a brake hose from the strut, or stabilizer links from the strut assembly. It usually results in a better answer if you take the time to mention YEAR, MAKE, MODEL, ENGINE SIZE, when you are asking for help with your vehicle.
Mar 17, 2012 | Cars & Trucks
696 people viewed this tip
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
