Try removing and replacing batteries to reset the camera. Ensure that batteries are fully charged.
If that does not clear the problem, then the lens error is
usually caused by mechanical faults concerning lens
assembly. This happens because there is dirt inside the lens (sand
dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is
detected and lens error is returned.
Sometimes this can be fixed
playing with the lens during extraction or retraction to help the lens
asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it
does not retract helping lens back in while turning camera respectively
on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
my kodak m1063 wont charge eventhoug i plug it directly to my computer... and whenever i zoomed it...
(More)
my kodak m1063 wont charge eventhoug i plug it directly to my computer... and whenever i zoomed it will auto turn off
my kodak easy share camera m1063 turns off as soon as i turn it on. i have 2 batteries and they...
(More)
my kodak easy share camera m1063 turns off as soon as i turn it on. i have 2 batteries and they are both charged and both do it. what could be the problem?
the lense will not open. it doesn't look broken jammed. it's just been dropped once. can you help...
(More)
the lense will not open. it doesn't look broken jammed. it's just been dropped once. can you help me? thank you!
