Tip & How-To about Water Heaters
How to repair a defektive ESBE Type 66 Electronic Motor Actuator 12001414
symptoms:
the actuator motor stops working
after manual operation it start to work again
sporadic failure
problem: cracked solder joint around the microswich pins on PCB
remedy or solution:
resoldering of the cracked joits
Water Heaters Logo
can I purchase intermatic timer motor 240v 50hz P/N WG 1574 10D in Australia?
The motor will turn faster with higher frequency because the phase changes is faster. No damage to the motor. Just ensure that the voltage is within the operating range. Amperage kills the motor, subjecting high loads on it will eventually burnt it's windings and become expensive to repair.
Jun 10, 2016 | Intermatic EH40 240-Volt Electronic Water...
Goldline GVA-24 valve actuator is leaking
the leak is from the shaft of the valve need new oring
Apr 24, 2013 | Goldline Controls Goldline GVA-24 - Valve...
stop 2min and run for 2min, stop 2min and run for
your motor thermal safety relay is protecting the motor from burning out
this is usually caused by: an old motor about to fail (tight shaft bearings) bad centrifical switch or, an obstruction in the water flow causing the motor to work too hard (draw too many amps, get too hot then cool down and, start up again
check the relay it is located on the side of the motor on most motors; under a cover; unless the motor is bad the relay may just be too sensitive (old) and, may need to be replaced.
Jul 24, 2010 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
973 people viewed this tip
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
