Tip & How-To about Dell M787C Wireless Mouse P/N: M787C - Originals
Dell wireless mouse M787C batteries are wired in Parallel not in series Manufacturing error
Hello All, I just received a Dell All in One Computer with the M787c wireless mouse. I installed 2 fresh batteries and noticed after 3-4 minutes one of the batteries was getting warm? I removed that battery and the mouse LED light was still working. SO the M787c mouse was working as it should with only ONE Battery!
I checked wiring of the batteries and found that the Batteries were WIRED in Parallel. Wiring batteries in parallel is not a very good Electrical practice, at all!
I am sure that many owners of this mouse have gone through many batteries because of the miss wiring.
If you mouse does not work with properly with one battery if you are mechanically inclined you can disassemble the Mouse and rewire the batteries in SERIES.
There are 4 screws on the bottom of the mouse, 2 in the bottom underneath the front gliders, and 2 in the top. Happy fixing. Rob
Dell M787C Wireless Mouse P/N: M787C - Originals Logo
MOuse batteries wired incorrectly
Mcyman,
Can you please provide more information on your post about the mouse batteries being wired incorrectly? I can then look into the issue.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 29, 2016 | Dell M787C Wireless Mouse P/N: M787C -...
new mouse for the keyboard combo does not work
Go to Facebook > Dell > Send a message > Add all the details possible > wait a bit for the reply > here you go! fixed!
Mar 20, 2012 | Dell Inspiron One 2305 Desktop Computer...
Optical light on Mouse not working
maybe the battery?
follow the steps below to troubleshoot the mouse
Wireless mouse does not respond (generic instructions)
Try to Resynchronize your device with the receiver(connector)
Follow these steps.:
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse at least 6 feet away.
1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
2. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
3. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 3 again.
For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
or
Try different port and restart your computer.
or
Reinsert the batteries or install fresh batteries
If you have the possibility check whether the problem is because of your computer or the device, try the mouse or the keyboard on a different computer.
Sep 06, 2009 | Microsoft Wireless Notebook Optical Mouse...
wireless mouse freezes the screen goes white it is a dell monitor i have had for about 3/4 years and a cheap wireless keyboard and mouse which i have had for about 2and a half years just started today already done it twice
Are the batteries fresh in the keyboard and mouse? Do you have USB keyboard and mouse to try (to eliminate possibility of wireless keyboard / mouse failure) If you do have alternate (USB or PS/2) keyboard and mouse, make sure and unplug the USB receiver for wireless set before testing. Let me know results.
Jul 09, 2009 | Dell Computers & Internet
dell wireless mouse and keyboard-no instructions
Most Bluetooth keyboards and mice are just Plug-n-Play and does not require any driver installation. You need to isolate the problem, please follow the steps below:
1. Make sure that the wireless adapter of your wireless KB and mouse is properly connected to the USB port of the computer.
2. Make sure that the USB ports of your computer are working.
3. Use fresh batteries for the KB and mouse.
4. After connecting the wireless dongle to the computer, turn on your KB and mouse (there should be an ON/OFF switch underneath).
5. Briefly press the connect button on the wireless dongle and then hold down the connect button underneath the mouse for five seconds and then release it.
6. Do the same steps for the KB.
Have a good day!
Jun 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
665 people viewed this tip
mukhtar21 shaikh
mukhtar21 shaikh
