Tip & How-To about Google Chrome
What to do when Chrome won't open
Occasionally, it happens: you double-click the Chrome icon and the more you wait, it just does not open.
The frequency with which this problem has been going on with the browser users was enough for the company itself created a small support page with tips on what to do if Google Chrome is not opening at all on your computer.
The following Google's tips on what to do if Chrome does not open:
- Restart the computer.
- Temporarily disable the antivirus and firewall computer - they may be preventing Chrome to start. If this is the case, you must create an exception in the firewall or antivirus settings.
- Download Chrome Canary (one end version of Chrome that Google uses to test new products) and try to start Chrome normally.
- In Windows, if you need Reboot every time you want to open Chrome, open the Task Manager (Ctrl + Shift + Esc) and check that there is still some instance of open chrome (if any, close it).
- Uninstall recently installed programs (especially if there is one whose name you do not recognize). They can be harmful programs that cause conflict with Chrome on purpose. In Windows, you can use the Chrome Cleanup Tool. Chrome Cleanup Tool
- It is also possible that your browser user profile is corrupted. In this case, you must create another. Create new browser user profile
Google Chrome Logo
How do I disable InCognito mode turn off
First, open the registry editor:
  1. Open the Start menu
  2. In the search box, type "regedit"
  3. A program called regedit.exe will appear, click on this
  4. If a warning comes up click Yes
Next, navigate to the Policies key:
  1. Start by double clicking on "Computer"
  2. Then, double click on "HKEY_LOCAL_MACHINE"
  3. Next, double click on "SOFTWARE"
  4. Finally, double click on "Policies"
Next, create a new entry called IncognitoModeAvailability:
  1. Right-click on "Policies" and select New >> Key
  2. Enter "Google" (without the quotes) as the name of the key
  3. Right-click on "Google" and select New >> Key
  4. Enter "Chrome" (without the quotes) as the name of the key
  5. Right-click on "Chrome" and select New >> DWORD (32-bit) Value
  6. Enter "IncognitoModeAvailability" (without the quotes) as the name
  7. Right-click on "IncognitoModeAvailability" and select "Modify..."
  8. Type a 1 in the "Value Data" text box
  9. Click OK and exit the Registry Editor program
Restart Google Chrome and now if you open the settings menu, the "New incognito window" option will be disabled.
https://www.internetsafetyproject.org/wiki/how-disable-incognito-mode-chrome
Dec 18, 2014 | Acer AC700-1099 Chrome book Wi-Fi
When I click google Chrome icon I cannot get my Gmail
Clicking the Google Chrome icon will always just open the Chrome browser. Once you have the browser open, type http://gmail.com into the address bar and you will then be directed to Gmail where you can sign in and check your email.
Hope that helps!
Nov 18, 2012 | Google Chrome
I believe I have downloaded Google Chrome Browser at least 4 5 times and I still cannot find it. I would like it to be my home page. I am a beginner with computers and its becoming very frustrating. I have gone in to my control panel a number of times. I can see the icon representing GCB but nothing....I am now after sending this off will go back & uninstall may have to start all over. Ur help would be appreciated. I also tried doing what was suggested if there was an error no luck
June,
On the screen, in the left down corner you will find some small icons. Either one of them is the Chrome icon or on their right there is a double arrow. If you click it you will have some other icons popping up. One of them is the Chrome icon. Click it open. I hope you remember what it looks like? It is a blue ball with red, yellow and green padding around it.
Mar 21, 2011 | Google Chrome
Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server connection failed.
open google chrome
to the right of the address bar is a wrench icon, click on it.
almost at the bottom of the list it says options, click it
click on the tab that says " under the hood "
next click the button that says change proxy settings
in the next box that pops up, click on "never dial a connection"
next click on the LAN button
next ensure that all check boxes are clear, with no checkmarks in them
click ok
then click ok again
that should bring you back to the google chrome options box
click close
close out chrome
wiat about 10 to 15 seconds to allow for chrome to recognize the new settings
reopen chrome and you should be able to use it just fine
Dec 18, 2010 | Google Chrome
I cannot open email attachments when using google chrome. I get a box in the bottom left of my screen saying starting, if I click the box the message changes to 'opening when complete' but nothing ever actually donwloads.
hey it is very easy . you just need to go in download tab . to reach thare u need to click the settings icon ontop right corner of chrome browser. there you will see download and other options just click on download. now a new tab will open showin your downloaded attachment and things which u have downloaded u can now open it directly by double clicking or right click on it if u want to open a foldr containing attacment.
Apr 06, 2010 | Google Chrome
404 people viewed this tip
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
