Tip & How-To about Home
How To Replace The Sash Lock on a Window
Learn how to replace the sash lock on window. This repair will help fix a drafty window, or may even help to fix or prevent a window from rattling or shaking in the wind.
Home Logo
i have a 99 camaro ultra z, and after taking the driver side door panel off [because my window was not rolling up the way it should] i found the window was not on the back window track because the pin pulled out of the bracket. my question is what is the name of the bracket and where can i get one. thank you for your time.
You will probably be better off changing the entire window regulator. It's the entire assembly, which bolts into the door, and guides the window up and down. Trying to fix individual parts of this regulator might not work and may end up being costly.
Oct 11, 2010 | Chevrolet Camaro Cars & Trucks
window tilts forward when going up
The forward track channel has either rusted out, broken, or the sash clips to help keep the window level broke. We have seen all the above, but most likely is the sash clips that glue onto the lower window broke. The door panel will have to be removed, the old clips, heated with a HOT heat gun and removed, and new ones installed. Pretty easy fix with the right equip.
Jan 19, 2010 | 2000 Pontiac Montana
How to install a door glass for a Chev C10 . I am have problems install the glass at the Drivers door. I need some help. As soon as possible
GM Full-Size Trucks 1980-1987 Repair Guide
REMOVAL & INSTALLATION
(see Figures 1 and 2)
Non-Stationary Door Glass
  1. Lower the door glass completely.
  2. Remove the trim panel from the door.
  3. Remove the ventilator assembly as previously outlined.
  4. Slide the glass forward until the front roller is in line with the notch in the sash channel.
  5. Push window forward and tilt the front portion of window up until rear roller is disengaged.
  6. Put window assembly in normal position (level) and raise straight up and out.
  7. Installation is the reverse of removal.
Fig. 1: Door window and regulator
Fig. 2: Removing the door glass
Manual Door Window Regulator
(see Figure 3)
  1. Raise the glass to the full up position and tape it to the door frame with fabric tape.
  2. Remove the door trim panel.
  3. Remove the regulator to door panel attaching bolts.
  4. Slide the regulator assembly rearward, disengaging the rollers from the sash panel.
A notch is provided in the sash panel to allow disengagement of the forward roller on the window regulator.
  1. Collapse and remove the regulator assembly through the access hole in the door.
To install:
  1. Prior to installation, lubricate the motor drive gear and regulator sector teeth.
  2. Collapse the regulator and insert it through the access hole in the door.
  3. Unfold the regulator and engage the forward roller to the sash cannel at sash channel notch.
  4. Slide the regulator rearward to engage the rear roller to the sash channel. Also engage the lower roller to the regulator rail.
  5. Slide the regulator into its proper position, and insert the regulator drive through the door panel.
  6. Attach the regulator to the door.
  7. Install the door trim panel.
Fig. 3: Manual window regulator
Power Window Regulator and Motor
(see Figure 4)
Fig. 4: Power window regulator and motor
  2. Disconnect the negative battery cable.
  3. Remove the door trim panel.
  4. Remove the remote control bolts and lay the control aside for access.
  5. Remove the regulator to door panel attaching bolts.
  6. Disconnect the harness from the regulator.
  7. Slide the regulator assembly rearward, disengaging the rollers from the sash panel.
  1. Remove the regulator assembly through the access hole in the door.
CAUTION Step 9 must be performed when the regulator is removed from the door. The regulator lift arms are under tension from the counterbalance spring and can cause serious injury if the motor is removed without locking the sector gear in position.
  1. Drill a hole through the regulator sector gear and back plate. DO NOT drill a hole closer than 1 /2 inch; to the edge of the sector gear or back plate. Install a pan head sheet metal tapping screw (No. 10-12× 3 /4 inch;) in the drilled hole to lock the sector gear in position.
  2. Remove the motor to regulator attaching screws and remove the motor from the regulator.
To install:
  2. Install the motor to the regulator. Make sure the motor and sector gear teeth mesh properly before installing the retaining screws.
  3. Remove the screw locking the sector gear in the fixed position.
  4. Reposition the motor in the door and install the wiring connector.
  5. Attach the regulator to the door.
I really hope help you with this (remember rated this help) Good luck.
Oct 06, 2009 | 1980 Chevrolet Corvette
car window is off track
what happens with these grand amsare that the windows have whats called a sash glued to the bottom side of the window, and bolts to the regulator. it has one for each track of the regulator. one of them has broke or the glue came loose. the window must be removed, and id the sash is broke you can buy a replacement from the dealership. and urethane it on. run a tape line on the glue edges as a guide then remove old glue glass prime and urethane back on. sashes are not expensive I've replaced many
Jun 23, 2009 | 2002 Pontiac Grand Am
543 people viewed this tip
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
