Tip & How-To about Kitchen Ranges
How to replace oven door roller assembly in Britannia Si-9TF-SS Range
I took a chance and ordered a new roller unit although the supplier advised it would not fit my Britannia cooker S1-9TF-SS. In fact the roller assembly fitted IS the same but the hole in front of the roller assembly (in cooker body) is 2mm too narrow to remove the old unit.
I removed the screw (1) holding the old assy and pushed it back into the oven side.
I then filled the slot in the side of the oven, taking 1mm+ each side until new assy fitted through. I used a stiff wire hook to hold the assy so I could pull it back into place, replaced the screw and I now have a working oven door. Espares part was better than old unit and I will now replace the roller assy on the other side of door. The small oven door does not get much use so still works fine. Job took about 1hour plus and a bit of bad ******
Kitchen Ranges Logo
need manual for Britannia ilve range cooker
You may have the cooker oven set to automatic. Phone their Service Team on 01253471111 option 3. They will help you fault find. The ID strip with all the cooker information is inside the right hand oven on th right hand side.
Jun 08, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
brittania SI/9TB/SS fan in main ove glows red hot
There is a fault on you oven please ring Britannia for a service call on 01253471111 option 3. They can also supply a new oven seal
May 07, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Rangemaster toledo DF 90 what is the minimum door width through which these cookers can be fitted?
Yes, the handle, doors and knobs can all be removed, in fact (If I remember correctly) the unit is delivered with at least the handle/rail at the top not fitted. I would still suggest that you visit the supplier with a tape measure and suggest that if they want sell you a unit, they reassure you by showing you a packaged unit, or demonstrate the removal of the handle.
Sep 24, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Model number SI 9TF GRA Britannia Range Cooker
my larger oven on my britannia range has stopped working would it be the themostat and how much would this cost and can i fit it myself? the grill is working and so is the small oven can anyone help please. ben.
Sep 01, 2008 | Britannia SI10T6L Dual Fuel (Electric and...
208 people viewed this tip
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
