Tip & How-To about Dorman 604-214 A/C Heater Blend Door Lever
2011 Dodge Charger Heater Blend Door Actuator
When you hear a loud clicking sound behind the dashboard, it's not the blower motor. Start by removing the side panel on the right side of the glove box. This will give you access to two screws. Remove the glove box door and pull it of the hinge when the door is at a 90 degree angle.
Once the glove box screws are removed the glove box comes out. Remember to remove the push trim clips. I recommend replacing them with new ones once you put it back together.
There's a bottom panel that also has 3 trim tabs that need to be replaced.
I added pictures to show the locations of everything.
I had to use a T15 star bit to remove the two screws holding the actuator in place.
There is red tab that needs to be pulled out first before pulling the electrical connector for the actuator.
I will add video later if anyone needs it.
Actuator
Actuator Blower Side
Actuator Location
Actuator Outer Side
Star ***** Removal https://youtu.be/_Q8F50sd7TU
Dorman 604-214 A/C Heater Blend Door Lever Logo
Do you access the blower motor on an 04 bonneville from under the hood or passenger side behind the glove box?
passenger side under the glove box ,
Remove the right side sound insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gages and Console.
Disconnect the electrical connector (1) from the blower motor.
Disconnect the blower ventilation tube (2) from the module.
Remove the blower motor screws (3).
Remove the blower motor from the housing.
Removal Procedure
Remove the fasteners at the rear edge of the insulators in order to disengage from the lower instrument panel.
Pry out the retainers in order to release.
Turn the heater temperature sensor 1/4 turn in order to release and allow to remain connected to its wire (CJ2 vehicles only).
Disconnect the electrical connectors.
Slide the insulator rearward in order to remove.
Sep 11, 2016 | 2004 Pontiac Bonneville
hearter temp control was blowing too hot, now only blows cold
Clicking sound you hear is the worn brushes in your blower motor. At this point the blower moter may or may not start with the switch. THe blower motor is faulty so I would change that first, then check for vacuum leaks or faulty selector cable for the heat blend door. It could have came off door side or heater control side.
Dec 14, 2013 | 2010 Dodge Nitro
I have a 2002 pontiac grand prix doesn't blow any
    • 1 Start the engine of the car and allow it to run for a few minutes. Adjust the climate controls. If they do not feel right, then the problem is probably in the control panel. If the controls feel fine, but have no effect on the air then it is probably a blown fuse. If you cannot hear the accompanying blowing sound when the air is turned from low to high, then the problem is in the blower motor.
    • 2 Disconnect the black negative battery cable first when looking for the blower motor. Remove the trim panel and unplug the electrical connectors from the blower motor. Unscrew the retaining screws and remove the blower motor and fan.
    • 3 Check the control panel next. Disconnect the negative battery cable first. Remove the screws securing the cluster trim plate to the instrument panel and tilt the top of the cluster trim plate downward releasing the clips that mount the bottom of the trim plate to the dash.
    • 4 Remove the trim plate. Remove the screws attaching the accessory trim center plate to the dash. Tilt the top of the accessory trim plate downward releasing the clips that mount the bottom of the plate to the instrument panel.
    • 5 Use a screwdriver to unscrew the screws attaching the control assembly to the dash. Remove the control assembly from the dash. Disconnect the electrical connectors and remove the control assembly.
    • 6 Replace a blown fuse in your Grand Am easily. There are two interior fuse boxes in Grand Am, but the right fuse will be found on the passenger side. Open the door and pry off the side panel to the right of the dashboard. Use the guide on the inside of the panel to find the right fuse.
Oct 07, 2011 | 2002 Pontiac Grand Prix
how do I replace blower motor for heat and air conditioning, the blower is under the dash board
Removal Procedure
  1. Remove the right side sound insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gages and Console.
  3. Disconnect the electrical connector (1) from the blower motor.
  4. Disconnect the blower ventilation tube (2) from the module.
  6. Remove the blower motor screws (1).
  7. Remove the blower motor from the housing.
Installation Procedure
    Notice: Refer to Fastener Notice in the Preface section.
  1. Install the blower motor into the housing.
  3. Install the blower motor screws (1) .
  4. Tighten
    Tighten the screws to 1.7 N·m (15 lb in).
  5. Install the blower ventilation tube (2) to the module.
  6. Connect the blower motor electrical connector (1) .
  7. Install the right side sound insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gages and Console.
Jul 30, 2009 | 2002 Buick LeSabre
334 people viewed this tip
Top Dorman Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Dorman Heating and Cooling Expert? Answer questions, earn points and help others
