Tip & How-To about Electrical Supplies
Warning for electrical work!
It is scary reading some questions on electrical work. When someone asks how to wire a circuit panel, that worries me. Please do not work on any electrical equipment if you are not trained in electricity. Even if the power is off, there is always a possibility for electrical shock! Not only is your personal safety at risk, but also your home! Fires can start with improper wiring. If you are unsure, please don't take a chance, call a professional! Stay safe!!!!
Electrical Supplies Logo
2004 buick lesabre driver side rear running lights off...break lights work...whats wrong.
It's not that simple , What's wrong . Do you know how to do automotive electrical testing ? Because that's how you find electrical problems . You find a wiring diagram , componet location diagrams , use a voltmeter and test the circuit . Watch these videos . Electric Testing Techniques You Need to Know Training Series How to read an electrical diagram The Trainer 18 Electrical Testing Tips
So asking what's wrong , you expect someone on here to make a guess , and that's not how it's done . If you can't fix it with all these videos , you need to take it to a qualified repair shop .
Feb 06, 2017 | Buick Cars & Trucks
We replaced the resistor on heater ford escape 2011 in Nov 2016.Our heater is doing the same thing again..do you think could be bad resistor?
Why ask someones opinion on here ? Learn to test the electrical circuit . Videos on youtube for basic automotive electrical circuit testing , how to read a wiring diagram. You can find free wiring diagrams at http://www.bbbind.com/free_tsb.html Blower Motor Problems Auto Repair Help Rather then just replacing parts !
Jan 30, 2017 | Ford Cars & Trucks
electrical
Could be a blown fuse on the power pole. If one phase has a blown fuse you will get less voltage at the house.
Jul 17, 2015 | Electrical Supplies
to connect to breaker panel I have 2 15 amp breaker how do I connect my wireing where the black go and the white go what about the two breaker
circuit breakers snap on to the panels. the black(or red) hot wires attach to the breakers. the circuit breaker protect the hot/live wires. the white/neutral wires attach to the neutral bar in the circuit breaker box just like the ones that are already there. the green/ground wire attach to the ground bar, like the ones already there. however, if you have to ask, you may not want to do this on your own. find someone who knows what they are doing. electricity kills. if you really don't know what you are doing, can get you severely injured, or start a fire, or hurt someone else. find some help, please.
Mar 15, 2015 | Electrical Supplies
renting old house with old power box uses 'plug in fuses' , doesnt have cut off safety switch ,i heard that i can by circut breakers to stop any surges and plug them into fuse box ,does that sound right ? cheers
Wow, all due respect, but someone would really be negligent to offer you a solution to this problem. An electrical panel isn't something to mess with, especially if you're asking these type of questions. Contact a professional electrician in your area or run the risk of electrocuting (that's DEAD by electricity) yourself. Good luck, and please be safe.
Aug 10, 2010 | Eaton ARC FAULT CIRC BREAKER
503 people viewed this tip
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
