Tip & How-To about Eternal GU195S On-Demand Hybrid Condensing Gas Fired Water Heater 98% - 199,0
How to chnge light bulbs in the headlights of 2013 Ford E-350
Pop the hood. There are 3 bolts holding the headlight in place. One 8mm bolt on top attaching the light to the cross frame. Two 7mm bolts located toward the bottom of the headlight. They are between the headlight and the bumper. You may need a flashlight to see them. Remove all three bolts. Pull forward on the headlight. You will feel a push in clip release from the outside edge of the headlight. You can now move the headlight forward for bulb replacement. Reverse instructions to reinstall.
Eternal GU195S On-Demand Hybrid Condensing Gas Fired Water Heater 98% - 199,0 Logo
Where is location for anode rod?
The anode rod on a hot water heater is usually located on the top. There's usually what looks like a bolt head that you can undo with a wrench to remove the rod. It will be directly on the hot water heater and won't be part of the water lines running in.
Nov 24, 2015 | Water Heaters
Rheem 41v850 leaking at bolt on top
just turn off the gas valve for pilot light, turn off cold water to water tank. drain system. when refilling open cold water to fill tank, wait at least a 1/2 hour to 45 minutes then relight water heater. you should be fine!
Mar 29, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Where is anode location on a 100 gallon gas commercial water heater, model number G100-250?
There should be a hex bolt on the top of the water heater. Unscrew the bolt, the annode is attached to the bolt. The annode will be almost as long as the tank itself, so you should alow for vertical clearance.
Jan 26, 2011 | Rheem Water Heaters
DIDNT GET INSTALLATION INSTRUCTIONS WITH MY E-75 WATER HEATER SAFETY STRAPS. ANY SUGGESTIONS?
1) Watts doesn't seem to have installation manual.
Page 7 on sales-brochure/manual shows your product assembled.
http://media.wattswater.com/F-Spcmkr.pdf
2) Add a comment for more free help.
3) Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater straps or any do-it-yourself project. Give phone rep link to brochure/manual so they can speak to you about each individual part while you describe location of your heater and type of wall surface.
Fixya is always less expensive than a service call.
Jan 16, 2011 | Watts E-75 Earthquake Water Heater Safety...
This water heater has two elements, correct?? Well how do you get them out?
The first thing to do is shut off power supply to the heater. Then while water is still on hook up garden hose to drain valve on bottom of heater. Place hose to floor drain or some other location for safe drainage. Open drain valve and if it starts draining at a good rate then shut water supply valve off to heater. You will want to open hot side of closest faucet to prevent vacumn which will slow or stop draining. After heater is done draining shut off drain valve and faucet . Remove the cover plates on top and bottpm of heater. Usually four small screws. Locate heating elements and disconnect wiring,label if you need to for reinstallation. There are two kinds of heating elements,one is held in place with 4 hex head bolts,and the other is screwed in. If yours has the bolts carefully remove to avoid breaking bolts.Then just pull out to remove To reinstall there will be a new rubber gasket with element, fit it in place and insert element back in heater. Reconnect wires. If there are no bolts apparent then the element screws into heater. You will need a pipe wrench or large wrench to remove the element. The same thing with this element is that it should have a new rubber gasket. Put gasket in place and wrap threads with 5 to 6 wraps of teflon tape. Install element and tighten snugly. Connect wires,refill with water and check for leaks. If no leaks then turn power back on. Put cover plates back on and you're done. I hope this helps you. Thanks
Nov 19, 2010 | Audiovox Richmond 6EM30-2 30-Gallon 6-Year...
460 people viewed this tip
Top Eternal Water Heaters Experts
Paul Carew
Gil Shultz
Are you an Eternal Water Heater Expert? Answer questions, earn points and help others
